hunting idle ........ and 'tick tick tick'
philg
Post by philg »
yes hunting is when its revs up and drops around whatever revs it should be at, but cant sit constantly at the correct revs. mines only does it when the car is idling. That suggests that one of the sensors is dodgy.... or.... theres is air leaking into the system between the throttle body and engine head, a sensor is picking up on this and trying to supply fuel to compensate for the extra air, but just cant get it right.
I'm still a bit wary(sp) of whether an injector could be making this ticking noise. It sounds more like a valve/lifter clicking against its seat. Do these cars have hydraulic lifters does anyone know?
philg wrote:I'm still a bit wary(sp) of whether an injector could be making this ticking noise.
Hence why I suggested touching them to feel if it is or not.
dmcwe
tick,tick,tick
Post by dmcwe »
mines a 2.0 ltr 1998 and has had a tick for ages, it`s more annoying than anything. I also had the revs "hunting" some time ago, that was the stepper motor.
Am I the only clown here?
Benner
Post by Benner »
Have just looked today and mine seems to do the same thing!!
I knew I had a faint tapping, but after reading this I thought I'd look at my rev counter and it seems to fluctuate just above and below 1000rpm. This was not long after start up though and I forgot to look again at the end of my journey, so it may have just been a start up thing.
philg, you say yours does it. How much does it fluctuate by?
philg
Post by philg »
yea mine is the same benner, just either side of 1000rpm.
so is the consensous(sp) that a new stepper motor will sort this? what sorta £££ do them things cost.
Benner
Post by Benner »
Have just gone out and had another look and it's not as bad as I thought it was. It's probably always done it and they may all do it.
However, on close inspection I have noticed a hole in my rear box :cry: so could this be anything to do with it? Don't really know a lot about pressures.
Benner
Post by Benner »
Have done 3 journeys today and it hasn't done it so it probably was just where I had started it.
This is obviously a common thing and I would also be interested in the cost of the stepper motor if anyone knows?
If you lot had the mighty diesels, you'd have none of the hunting. It would sit rock solid on 850rpm :D
I don't know anything about petrols, but I know my housemate's Rover :!: does it and my ex-boss's Skyline... all "hunt" around, especially when cold.
Pyros6546
Post by Pyros6546 »
mines fine never does it 2.0l glx 16v
as long as its not causing any problems
then does it really matter try cleaning
the stepper motor.
Benner
Post by Benner »
Dont think it matters at all. As long as it doesn't fluctuate too much and cause the revs to drop so low that it stalls.
Yes have had a read and it is suggested to clean the stepper.
darrenwall
Post by darrenwall »
sometimes the revs " hunt " up and down if you have got an air leak , like a blowing manifold gasket or something round there , and as for the ticking that should be just the injectors opening and closing , try some fuel cleaner in your tank to see if that quietens them down
Pyros6546
Post by Pyros6546 »
check the sensors in the engine
coolant and rpm sensor either
one can cause problems 1 of
them could have an intermittent
fault
