Think i need a new clutch, what should i be paying??
- Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
Re: Think i need a new clutch, what should i be paying??
Had the clutch and dmf replaced on my 406 hdi have to say both are uprated now and clutch is a delight compared to before if it was your dmf it would be slipping. Also i noticed i no longer get any vibration at speed of around 80mph which i had before.
Mines fine and dandy,quite slick really, yes its really high but i'm used to it now.
Only problem is sometimes it wont engage reverse, i have to release the clutch and then press it down again before she slots in
- jameslxdt
this is typical of a pug gearbox, reverse is always bloody awfulTooT wrote:Only problem is sometimes it wont engage reverse, i have to release the clutch and then press it down again before she slots in
So it is not just me thenjameslxdt wrote:this is typical of a pug gearbox, reverse is always bloody awfulTooT wrote:Only problem is sometimes it wont engage reverse, i have to release the clutch and then press it down again before she slots in
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
- DaiRees
- Site Admin
Me three!V6Exec wrote:So it is not just me thenjameslxdt wrote:this is typical of a pug gearbox, reverse is always bloody awfulTooT wrote:Only problem is sometimes it wont engage reverse, i have to release the clutch and then press it down again before she slots in
A tip i would give is engage reverse before starting the car if possible
Thanks for all the words of support guys, I am starting to get the feel of it now, and the paranoia of a possible new clutch is starting to fade
I call her Starbug 1, because she's green with intergalactic milage!! I do love my D8 diesel.
I keep light pressure on the gearstick towards reverse, then bring the clutch up to just before biting point, at which point 9 times out of 10 the gearstick will slot in without much effort
- Captain Jack
Yes, me too. Although, sometimes I do get that horrible grinding noise if I am not careful. An alternative is to put it into first and then reverse.mjb wrote:I keep light pressure on the gearstick towards reverse, then bring the clutch up to just before biting point, at which point 9 times out of 10 the gearstick will slot in without much effort
And yes, my biting point is very high as well. When I bought the car 4 years ago, I took it to my local Pug specialist for a clutch replacement, but he said all 406's are like that. It's been fine. Although, I am probably looking at a clutch change soon (on 132k miles now with original). Thank fk, I don't have that horrid DMF......
by reading this post am I right in thinking the d8 as a cable clutch and no dmf fitted
2.0L 8V TURBO EXECUTIVE 150BHP+TOYS ZRX1200R AND MK1 EUNOS ROADSTER
- Captain Jack
No DMF on any of the D8's. The 2.1TD's and the V6's have hydraulic clutchesDeano wrote:by reading this post am I right in thinking the d8 as a cable clutch and no dmf fitted
that will do me Captain Jack as I am a cheap skate
My 2,1 and the 2,0 HDi have hydraulic clutches (almost the same gearbox too AFAIK), I have no problems engaging reverse, unless I get too keen and try shoving it in before the layshaft stops spinning - crunchy!
I did read 406's had horrible gearchanges, I seem to have lucked out on that one!
Do yours balk or crunch?
All this talk about my d9 clutch, and then the clutch cable goes and snaps on my d8 (taxi) at 2230 on the busiest Saturday night in ages! If bad luck was horse muck, I'd need a wheelbarrow!
The 2.0 turbo (at least the exec version) also has a hydraulic clutchCaptain Jack wrote:No DMF on any of the D8's. The 2.1TD's and the V6's have hydraulic clutchesDeano wrote:by reading this post am I right in thinking the d8 as a cable clutch and no dmf fitted
