Sorry typo , passenger window , . So if the wipers work but not as they should
could this be caused by failing relay , or could both probs be caused by bad
earth as i know there are some earth points under the carpet .
Electric window problem ....
Re: Electric window problem ....
The front and rear wiper relays are inside the BSI. The switches only signal the BSI, the BSI itself controls the speeds and everyfink, the wiper motor signals the park position with an earth but, instead of switching this earth through to the motor, the BSI provides one of its own. You should hear both of these relays working when the wipers are in intermittant.
None of the earthing points or interconnects appear to be common and the only common cable is 10 PR. The BSI does not provide the earths for the windows, only the supply and if this wasn't going through then the windows wouldn't do anything at all.
Check for those earths. Check everything on the car for anything else that doesn't work. I presume the intermittants on both wiper motors don't work (?)
Cheers steve , will check everything to see what is and isn't working , do i
take it then that the relays for wipers can't be replaced and no there is no
clicking sound when i turn wipers on like there used to be .
Two relays failing simultaneously, even with puggy's aerobatics, seems a tad unlikely.
Might be worth a BSI reset first.
If that doesn't do it, scaring it with a PP2000 might, (my aircon's stayed fixed since I cleared an alleged short cicuit compressor fault in the BSI)
I'd try both before resorting to the soldering iron
Cheers lads , will try the reset if no luck will have a word with MJ think he's
got a pp2000 if not i will be heading your way doggy
Windows cured simply by replacing drivers window switch, though
i had removed passenger door card to check motor and totally stripped
and cleaned drivers switch before doing this
