The Mondeo :)
- Bailes1992
Re: The Mondeo :)
There is a belt to drive the fuel pump.
The belt is in a cassette and has an oil feed. It's designed to make the belt quiter and last longer (Apparently). This belt used to be a chain.
Then there is a belt between the fuel pump and the camshaft.
Re: The Mondeo :)
Nice little install there, but did you not use heat-shrink to insulate the soldered connection?
The scratch on the bonnet is quite bad, and there's a fair few stone chips - it might be an idea to think about respraying the bonnet for the best results (at a really good spray shop).
- Bailes1992
Re: The Mondeo :)
I didn't snip the reverse light feed I just simply removed some insulation so there was no way of sliding the headshrink ontothe wire. I did think about removing the pin from the plug to do it but just left it taped in the end.Welly wrote:Nice little install there, but did you not use heat-shrink to insulate the soldered connection?
If I respray the bonnet then the front bumper will have to be done too and they will have to blow the paint onto the wings. I think when I have the money, a full front respray is the way to go.
Re: The Mondeo :)
Nowt wrong with belt drives, tried and tested technology that beBailes1992 wrote:There is a belt to drive the fuel pump.
Re: The Mondeo :)
The ought to adjust the tension on that f*cker, could have someone's eye out
Re: The Mondeo :)
Don't worry about any errant eye balls, they won't damage the superb machinery.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Re: The Mondeo :)
Never mind eye ball, that's at head height and is probably quite capable of ripping someone's head off without pausing
- Bailes1992
Re: The Mondeo :)
Suspension has been lowered 35mm on Eibachs.
Car feels much more stable at high speed and seems much more settled on fast bends
Decided I'm going to bifuel my car with LPG. It would see me a 10-20% reduction in fuel costs and an increase of about 25% in torque. Coupled with a remap it would make my little 1.8TDCi a very pokey motor indeed! Probably running aroun 170bhp and 400nm.
But next thing to spend my money on is bodywork. I have to sort out the front end, it's irritating me now. Not sure weather to get the whole car resprayed or just the front.
Re: The Mondeo :)
Mind those speed bumps!
I didn't realise it had been lowered until I read the text so it's probably not too much.
I did read that you can lpg diesels but all you get is a power increase, you can't run it on just lpg. Did this change?
- Bailes1992
Re: The Mondeo :)
Nope you're right, thats why it's called bifuel.steve_earwig wrote:Mind those speed bumps!![]()
You can save fuel, not just because the LPG is half the price but because it increases the combustion chamber tempretures which means you get a more efficient burn.
That also means no smoke, faster turbo spool times and faster warm up times which also means less engine wear!
Re: The Mondeo :)
I'm hearing you on fm, in the winter the HDi never warmed up properly unless it went on a long run, I always worried about how much damage I was doing to it. Unlike the Yoyo...Bailes1992 wrote:...faster warm up times which also means less engine wear
As long as it's not too hotBailes1992 wrote:...it increases the combustion chamber temperatures
Re: The Mondeo :)
Looks good with the lowered sussy
I would be careful with LPG, purely my opinion but I wouldn't want anything which made the head run hotter especially with sensitive piezo injectors and then you'd be sending much hotter eggsauce gas at the turbo which'll be like "hey great more heat for me"...........also as a kinda 'cycle' the intercooler might struggle on hot days. I'd personally stick to a proper remap and keep it simple (you'd get better mpg then anyway).
- Bailes1992
Re: The Mondeo :)
The LPG is used in very small amounts. Usually around 10-20% of the amount of diesel being injected.
You have to think of it more as an additive than running it on two fuels.
Re: The Mondeo :)
Seems a bit pointless unless you're doing mega-miles then? sounds to me like something a fleet of lorries would benefit from? you'd have to check whether you'd even get near to recovering the cost of the system.
Quick google suggests your insurance shouldn't be affected BUT I actually saw an LPG Rangey on fire on the M1 a couple of years back - you shoulda seen it go up
closed the Motorway in both directions for fear of explosion
it was a massive fire I'd be amazed if an insurer didn't see LPG as a risk.
- Bailes1992
Re: The Mondeo :)
I'd be getting a UKLPG approved installer to fit it.
Based on an increase in economy of 10% I would break even after 18months-2 years.
I'm not doing Mega miles but pushing 25-30k a year.
