Hello All,
My 406 20l lx, should this have the trip computor??? not sure if stalk button broken or just not have it fitted to my spec of car, when i set the clock etc it asked me if i wanted kph or mph so is that standard or should this work and means my button is stuck or damaged it only has a very small movment if i try to push it.
thanks in advance
Paul
Trip comp
Re: Trip comp
Its a 'W' Reg so is a Mk2 406 aka D9.
Its probably got the right screen (MFD) but you may need a new wiper stalk with the bit on the end with two arrows which can be depressed.
You then need to find a local Pug dealer to go into BSI Configuration to enable the on-onboard computer.
We had to do this on my wifes W reg 406 LX HDi 90 Diesel... Stalk was about £20-30 and dealer charged £40 to do.
Re: Trip comp
Hey thanks Bruce,
Just a quick question tho, £20 for the stalk was that ebay?? was it easy to fit or was it all done by the dealer??
Paul
Paul
- Site Admin & Mad Biker!
Re: Trip comp
Stalk's a piece of cake to fit, steering wheel cowl off and two screws.
The dealer will connect up their diag machine and enable the trip function in the bsi.
Re: Trip comp
thanks Teamster, so will any stalk with push button fit?? as in will i have to look for a 2000 onwards and would estate on fit and work een tho it has rear wash wipe option??
Paul
Paul
