How do you remove tweeter grills in dash?
jason1987
Post by jason1987 »
and is it easy to put aftermarket tweeters from component speakers into the oem tweeter space? not sure if the wires are easy to get to
HimBigChief
Re: How do you remove tweeter grills in dash?
Post by HimBigChief »
It can be done, I've done it on mine. Uprated the speakers all round, but didn't know where the standard crossovers were so just used the existing wiring to connect to. Pretty sure they just pop up using a very small screwdriver IIRC.
Image Image
jason1987
Post by jason1987 »
is the wire easy to feed up?
HimBigChief
Like I said, pretty sure I just reused the existing wiring. I just cut and crimped the old and new wires together.
Image Image
jason1987
Post by jason1987 »
ill just unplug the tweeters and mount the new tweeters in the door mirror pods
HimBigChief wrote:It can be done, I've done it on mine. Uprated the speakers all round, but didn't know where the standard crossovers were so just used the existing wiring to connect to. Pretty sure they just pop up using a very small screwdriver IIRC.
the standard crossover is on the tweeter itself. 8)
So does that mean that if you remove the factory tweeter you either have to fit your own crossover if fitting new tweeters or replace with full range speakers? Been contemplating this myself as since I changed my stereo the tweeters now sound a bit farty when a bassy song is playing.
Id think the standard crossover is just a capacitor. I don't think you'd get a full range speaker that small but I'm ready to be surprised. What you really need is a decent crossover with decent tweeters in the dash and midrange in the doors
What ae the measurements of the standard tweeters then?
I dunno, tiny I guess.
A bit more googling later... This place says the replacements are 25mm, so I guess the real ones are something like that.
steve_earwig wrote:Id think the standard crossover is just a capacitor. I don't think you'd get a full range speaker that small but I'm ready to be surprised. What you really need is a decent crossover with decent tweeters in the dash and midrange in the doors
ye its the tiny capacitor on the back of the tweeter
waue1978 wrote:What ae the measurements of the standard tweeters then?
you can easily get them out to have a look, im not sure about the size of them cos i think there good and dont see the need to change them unless of course you want mids and tweets , all i gave done is stuck a good set of co-axial 2 way speaker in the door and left the tweeter alone,
get a small screwdriver and carefully put into edge of tweeter and flip it out, 8)
