Poor Starting in hot weather
michaeljclark
Post by michaeljclark »
Just a quickie and any help appreciated
With all this hot weather the 406 is suffering in the heat
It sits at the Satation for 10 hours and when I get back it a sod to start - normally takes 5-10 seconds of cranking before it bursts into life
Now when I put the key in (and move it to position 2) I can hear the whine of the fuel pump as normal for about 5 seconds - is it just that it's so hot at the mo (and the car is 10 years old) that the fuel in and around the pump is evapourating away? and it's having to draw it back from the tank
Once it's warmed up then it's not a problem, in cool weather it starts just fine
I wonder if it needs a visit to the main stealer for a major (100,000 mile) service even maybe so the diags can be read off?
Any thoughts anyone?
You haven't said if it is a petrol or diesel you silly boy :roll:
May be worth considering if the following parts have been replaced in the last couple of years:
Petrol:
Spark plugs/leads
Fuel Filter
Air Filter
Oil & Filter (won't affect starting but hey)
Try some injector cleaner
Main Fuel Relay (but you said you can hear the pump running)
Diesel:
Glow Plugs
Fuel Pump Fault
Air in system/bleed
Fuel Filter
Air Filter
Injector Cleaner
michaeljclark
Whoops
1.8 16v Petrol
It had new plugs, oil+filter, fuel filter about 2000 miles ago
Interestingly it's been Ok for the last two days!!!!
Cheers
Mike
Just see how it goes then, it could have been an alarm/immobiliser fault in the extreme heat - my alarm went funny the other day in the heat.
michaeljclark
Cheers Welton
Regards
Mike
