Indicators
dissolved
Indicators
Post by dissolved »
simple question - on a 2000 D9 LX should there be a clicking when the indicators are going? only thing that bugs me about the car!
2000 D9 1.8 LX Saloon - 42k
Re: Indicators
Not sure about 2000 cars, later ones have a very quiet, electronically generated, 'click' that comes from a tiny speaker in the Com2000 stalk assembly. (You can't hear them either). :roll:
Re: Indicators
My 1999 Saloon (early pre-COM2000 D9) does it. It's like a relay clicking on and off.
The 2002 Coupe (COM2000-equipped) does it too, but as Doggy mentioned, it's a softer sound. With the radio on, you can sometimes fail to hear it.
Both my old Mk. 1 Renault Clios did it too. I think it's actually very common.
Re: Indicators
Learn to live with it - there's worse than that around. The first Iveco Cargos used to have an annoying beep that accompanied the indicators.
dissolved
Re: Indicators
Post by dissolved »
mine doesn't actually click which i why i asked - the lack of a noise is actually more irritating!
benlowlew
Re: Indicators
Post by benlowlew »
defo get a click on my D9 2001 LX. can only hear it if the music turned down though but its definately a good solid click!!!
Re: Indicators
Does anyone know where the pre-Com2000 'click' comes from - is it a little speaker or something the OP can check easily?
RayneR
Re: Indicators
Post by RayneR »
dogslife wrote:Does anyone know where the pre-Com2000 'click' comes from - is it a little speaker or something the OP can check easily?
my 2000 estate does the sound, i don't wanna push my knowledge about it but, i guess the sound is produced from the speaker that does the bleeps if you miss the key plugged in on the dashboard, when the motor is off, and when you forget to turn off the headlights when the motor is off, but it can be a relay, one of these 2 things must be it, and i think is easily something to check.
plod
Re: Indicators
Post by plod »
waue1978 wrote:Learn to live with it - there's worse than that around. The first Iveco Cargos used to have an annoying beep that accompanied the indicators.
The Eurocargo (2004) I drive has a very annoying beep to it :frown:
1999 D8.5 HDi GLX - Sold :(
dissolved
Re: Indicators
Post by dissolved »
if they're combined then it would explain why it doesn't beep when you leave the lights on either. any idea which relay?
Re: Indicators
the new c4 if i recall the brochure correctly allows you to personalise the sounds, this being one of them.
RayneR
Re: Indicators
Post by RayneR »
FarmerPug wrote:the new c4 if i recall the brochure correctly allows you to personalise the sounds, this being one of them.
Can you explain more about that ?
Re: Indicators
The warning sounds, like door open, indicators, etc the menu allows you to choose a number of different polyphonic sounds for them.
Although i doubt the indicators one is going to allow you to have something like the nokia tune, its probably a choice of different indicator noises.
Still nice to have that level of choice.
RayneR
Re: Indicators
Post by RayneR »
FarmerPug wrote:The warning sounds, like door open, indicators, etc the menu allows you to choose a number of different polyphonic sounds for them.
where can i find " this " menu ? i didn't understand it right, What i must have to go to this menu ?
Re: Indicators
its only in the new c4, i read it in the brochure, probably for the top end cars.
and the c4 hasnt been released yet, or at least not many are about yet.
