driving about 60 mph im getting quite bad wind noise, sounds like its coming from the drivers door mirror?????
Any body have a cure thanks
Ps turning the radio up didnt solve the problem lol.
wind noise
Re: wind noise
yup sounds familiar
open the drivers door and look at the seal ibet its come loose
mine was bad for wind noise iglued the seal back in place didnt bother with putting new clips on,
might be worth a look to see if its the seal,
Re: wind noise
the clips, i had wind noise up the top of the seal, with new clips the squek left and wind noise was reduced a lot.
Re: wind noise
a had similar problem .. but this was a very very odd problem, at about +/- 90/100 km/h , it started to do a very noisy sound, it looked it came from the interior of the dashboard.
But after going to the garage a few times, and having someone with the same car, i could catch the damn thing, guess what it was ?
Was the upper seal of the front windscreen !!! Was upside down !!
I guess this windscreen was replaced and the rubber was not replaced in the right position, It was luck and a bit of hard to get it to the right position, we need to take it out and then put it back in in the correct position.. not very easy ..
Re: wind noise
Had similar, on the driver's side the seal was short by 15 mm or a end cap was missing?
Also, wipers, mine seem high at the point of connection to the blade, not sure how to resolve, any ideas?
Returned from the dark side and back to a 406
2.0 16v GTX HPi Saloon - China Blue Pearlescent 106k - One Owner from New - Full dealer History
Re: wind noise
Yeah, the seal is still short, something +/- about that size, but the noise as gone after swapping upside down the seal ..GTXJez wrote:Had similar, on the driver's side the seal was short by 15 mm or a end cap was missing?
DAMN! I have the same problem with my wipers !.. in the middle on them when they come down, in an specific area doesn't clean properly, as i think it isn't doing the enough pressure on the windscreen,
Re: wind noise
I'm thinking about changing the arms to maybe 407 ones which are fitted with the lower sitting straight fit 'Aero Blades' ?
that should lower them enough to sit behind the lip of the bonnet, and clean the screen better!!
Let you know how I get one!
Re: wind noise
yey, the 407's wiper arms fit in the 406 ? Is it really as you say ? They do more pressure on the screen ? Because i changed my wiper arm once, and didn't solved nothing ..GTXJez wrote:I'm thinking about changing the arms to maybe 407 ones which are fitted with the lower sitting straight fit 'Aero Blades' ?
