406 speedo stopped working
pugface406lx
Post by pugface406lx »
Hi there ....i've got a 2.0HDI estate yr 2000 W reg...nice condition car but have been unable to solve a few running probs.
1. Car is very sluggish and lacks power when i give it a bit of stick, in fact it sometimes goes into limp home mode for a while. The Maff sensor was suspected as the code reader said 'boost pressure' was at fault. I swapped this item but to no avail, still lacks power although gets up to road speed ok.
i changed the crank sensor too in case it was that was the reason....no change! Also changed the little 'denso' sensor near the slam panel which interlinks into the air intake system....still no joy. I wondered if its a prob with the Turbo??
2. The other day was doing about 30 then noticed the speedo dropped to 0 for about 10 secs whilst driving, also noticed a sudeen reduction in power while this was going on....then all of a sudden the speedo kicked in again and the car suddenly felt a surge in power like a judder as the power came back! any ideas guys please???
Puggy
Re: 406 speedo stopped working
#2 would be the speedo transducer on the back of the gearbox - I think you already worked out it also sends information to the engine ecu about speed and the lack of this is confusing it. You could try reseating the connector first.
Not sure about #1 but sort #2 out first, there's nothing like one fault masking another :frown:
pugface406lx
Thanks for the reply steve...I will look for that transducer.....is it easy to get to?...not sure what it looks like and where? Are they a replaceable item easy to get hold of?
It may solve problem 1 do you think if im really really lucky?
Cheers
Pugface
marco2002
Post by marco2002 »
Hi Puggy
I have exactly the same problem with my hdi driving along and now and again the speedo drops to zero slight loss of power then a couple of seconds later the speedo goes back to original speed and the power kicks in again.
When i was in GSF the other day they looked up a new transducer and its about £24 so its not that expensive to replace. I will have to get round to fixing this after getting the other jobs done. Let me know how you get on with yours.
pugface406lx wrote:I will look for that transducer.....is it easy to get to?...not sure what it looks like and where?
I know this is in French (and a BE gearbox) but it's just the pictures you're looking at: http://www.forum-auto.com/pole-techniqu ... 209704.htm
I'm not sure if a handstand down the back of the engine is possible, it's probably easier to get to from underneath...
pugface406lx
Re: 406 speedo stopped working attn marco
Marco...noticed you said u was quoted £24 for the speedo transducer, can you tell me where/what is GSF please as my main stealer wants over 50 quid from me!
Cheers
Puggy
pugface406lx
whos /whats GSF please
Hi there all,
Can anyone help with who or what is GSF?....is it a motor factors?
plod
Post by plod »
GSF is the abbreviation of German Swedish French, and yes they are a large national chain of motor factors
1999 D8.5 HDi GLX - Sold :(
Scrutim
Post by Scrutim »
Hi Guys,
Had to do this on mine, after it died on day one of a two week tour of Scotland!!
You can get to it from underneath, if you have a pair of ramps to drive up. Its a bit of a wrist killer to get out, but doable, the fixing bolt on mine was a torx screw, so make sure you have a good set to get the thing out with first.
I had a nightmare getting the new one in, cos it really blimmimn tight with a new o ring on it, I ended up using a huuuge pair of water pump pliers to ease it into position. Once in, and all connected up, everything was back working as good as ever, full power restored, lovely!
Hope this helps
1999 T D9 2.0 HDI Executive Estate
Stelvio Pass Veteran 2010 (brakes didn't like it)
Nil Carborundum Illegitimi
maxi
Post by maxi »
Got the same problem on my X reg 2.0lt HDI , What's the sensor that I can remove on top of the Gear Box housing for? As I gather there are two, although it's usually the one shown here that causes problems. Mine started after having the clutch change, coincidence? Do you think?
maxi
Post by maxi »
Many thanks, I'll give it a go this weekend! Is anything easy to do on a 406! :-)
RayneR
Post by RayneR »
maxi wrote:Got the same problem on my X reg 2.0lt HDI , What's the sensor that I can remove on top of the Gear Box housing for? As I gather there are two, although it's usually the one shown here that causes problems. Mine started after having the clutch change, coincidence? Do you think?
well, my friend is having this same issue and he's clutch was changed almost a year, he's speedo is having this same problem that it goes to 0 ...
So all of you confirm that is that transducer that is causing the issue ?
maxi
Post by maxi »
I've had the same problem on a 1.8 petrol T. Reg and also a 2.0 HDI. X.Reg According to my local dealership it's a regular problem the part with VAT is about £51.00. GSF is cheaper they quoted me £37 today. I've still not found out what the sensor is on top of the gearbox housing though, ( crankshaft sensor ?) Anyone know.
Barnsey
Post by Barnsey »
I have had the problem with the Speedo intermittantly stopping and starting for some time. Following reading this thread I bought a new sensor from GSF for about £24 and fitted it today. It has worked OK so far, but only time will now tell. My only qery is that I lost gearbox oil in removing the old sensor and had to top up. However, I am not sure that the level is right, I am sure that I put more in than drained out. You are supposed to fill the gearbox through the filler hole until oil starts to drain from that orifice. However, this is a bit meaningless when the car is jacked up on tilt.
rallyman
Post by rallyman »
My 406 has had the speedo going off and on for a few weeks.I disconnected the plug from the inducer cleaned it and put it back.I have had no problems for the last week so hopefully it was a poor connection so might be worth a try if anyone has same problems.
