407
john170277
407
Post by john170277 »
just aquired a 407 hdi with a blown engine, now i have a 52 plate 2.0 110 hdi with smashed rear end would the engine transplantfrom the 406 int othe 407 to make one good car i think the only stumbling block would be the 407s 6 speed box
Re: 407
I would think that if the engine in the 406 and the engine in the 407 are the same, you would be able to use the 407's 6-speed box. If not, then you could always take the 5-speed box out of the 406 as well as the engine?
Re: 407
I don't think there were engine variants common to both 406 & 407, (but I could be wrong).
I don't think there's any issue mating a DW10 to an ML6 gearbox, but we don't know waht the original engine was - could be a 1.6 HDi, in which case there may be problems.
The greater concern is probably getting the electronics to work - can't see a 406 engine ecu working in a 407, or an older engine working off a newer ecu. :?
Re: 407
I thought the 2.2 HDi was present in both cars (or was that the 406 and the 607 only?) and so I figured that the 110 HDi might have appeared in both as well.
Oh well. I'll butt out as I really don't know enough to be advising on this sort of thing - I completely forgot about the ECU :oops:
Hope this works out for you!
rwb
Re: 407
Post by rwb »
Just what is the difference between a 2.0 110 and a 2.0 136?
jasper5
Re: 407
Post by jasper5 »
rwb wrote:Just what is the difference between a 2.0 110 and a 2.0 136?
The main difference is that the 110 is 8 valve and the 136 is 16 valve.
The 2.0 HDi 407 is 136 16 valve, up to 2007, later ones are 140.
Bailes1992
Re: 407
Post by Bailes1992 »
2.0 HDi 136 is a Ford lump
The 2.0 HDi from the 406 won't fit.
The 1.6 is a no no.
Although I think the 2.2 might be a go but you'd have to swap most the ancilaries, injectors etc etc
jasper5
Re: 407
Post by jasper5 »
Bailes1992 wrote:2.0 HDi 136 is a Ford lump
The 1.6 is a no no.
The 2.0 136 is fitted to Ford mondeo, widely renowned as a huge improvement over Ford engines, it is also fitted to many of the Volvos amongst several others.
The layout under the bonnet along with the different subframe is completely different on the 407 to the 406.
Dogslife is probably correct about the electronics compatibility.
john170277
Re: 407
407 is a 2-0 136 on 08 plate in zenith spec if all else fails i could break it for spares
jasper5
Re: 407
Post by jasper5 »
john170277 wrote:407 is a 2-0 136 on 08 plate in zenith spec
My apologies, the 140 bhp came in september 2008.
Here is a list of specs.....http://www.parkers.co.uk/cars/specs/Sum ... model=1212
Re: 407
Just a wild suggestion, but if the original engine's got a bottom end problem, might it be possible to graft the 136 head onto the 110 block?
john170277
Re: 407
its not a bad idea i will ask at the local specialists to see what knowledge they have
rwb
Re: 407
Post by rwb »
jasper5 wrote:the 110 is 8 valve and the 136 is 16 valve
oh yeah, I remember now :oops:
I thought it was just the 110 with a 16 valve head and a few minor tweaks?
What do Ford call it? TDCI?
dogslife wrote:if the original engine's got a bottom end problem, might it be possible to graft the 136 head onto the 110 block?
That would be cool :D
But I would imagine that 1.6 110, 2.0 136, Mondeo and 407 have mutually compatible engine mounting points, but that 2.0 110, 406 is different to this.
