i am sure its on here somewhere but i can't see it lol.
Is there a "How To" ? what else would i need to do ?
The car is a oct 2001 2.2 HDi
Thanks in advance
steve_earwig wrote:Ooh-er mrs.
WOW ! i didnt realise they were that scarce, is that because the engines were crap or just expensive ? i really hope the later loldogslife wrote:Hi Ian & welcome to the forum.![]()
There's not so many of us 2.2 HDi owners about - only about 800 saloons / estates were ever registered in the UK. The engine is far more common in the 406 coupe and there is much relevant info on their website, http://www.peugeot406coupe.com/phpBB3/ including a detailed howto on cleaning out the dpf or 'FAP'.
I also recommend you have a look through my voyage of discovery, here viewtopic.php?f=1&t=10429&hilit=+aunty
All is not doom & gloom - you can convert your car to do away with the dpf, additive and all the complicated gizmos it needs to work and it need not cost you much - (about £50 if you pay someone to remove the element and buy a flash programmer to download a defapped file).
If you're located near someone with the kit, it's even simpler......
Whereabouts are you?
