Fag Lighter Fuse
Hangar18
Fag Lighter Fuse
Post by Hangar18 »
Doggy sez...
"A simple switch of the fuses" haha :D
Any idea which fuse to move where in a D8 to take the fag lighter from only working with a key in the ignition to perma?
Any guidance welcome!
1996 406 Executive XU10J2CTE
1995 405 GLX XU7JP
Re: Fag Lighter Fuse
You know how a blade fuse has 2 legs, and there's 2 holes in the fusebox to put them into?
Well, for two fuses in the 406 fusebox there's 3 holes. One's the fag lighter, the other's to the stereo. Just move the fuse to use the other hole
gumby6371
Post by gumby6371 »
from memory when mine was popping the lighter fuse it's on the far left of the panel on a D8 and as MJB says it has 2 positions for permanent or ignition on feeds, can't remember which way round either but it's easy enough to find out just try it with the ignition off :D
john170277
Post by john170277 »
is it the same on a d9
omega
Post by omega »
on a d8 i think its fuse number1 top left
Hangar18
Post by Hangar18 »
omega wrote:on a d8 i think its fuse number1 top left
I'll give it a go when I get home from work this evening and let you guys know!
1995 405 GLX XU7JP
