Did anyone tryed to swap the pre multiplex fob key into a flip key found on the full multiplex and on ebay there is also some cases with blade.
ps: I found on ebay a convertion case, but all of the cases i saw all have two buttons, my key has only one button ...will those still fit my internals ?
Flip key anyone tryed ?
Re: Flip key anyone tryed ?
i had a 2 button one id say avoid them them ebay ones flex when you turn the key, and stick too far out of the barrel so your knee can hit it which isnt good for the barrel or your knee either.
That's curious because i thought the newer/full multiplex 406's had them from factory like the 307.
So those ones have that problem ?
ps: why here all the remotes i see is only one button
, here the same button locks and unlocks the car .. i guess we are different in every single aspect
ps 2 : would a 2 button key work with car ? ( with my transponder key programmed in this one )
I searched and this two button remote key is for deadlocking, i suspect that this would work with my car, i think i saw something like that on pp2000 when i was playing with it ...
- NineWhileNine
- 1.6 8v
1987 Fiat X1/9
2002 406 Coupe S&B 2.2 Petrol Manual
Done: JVC KD-DB101 into stock JBL Amp/Speaker & Stalk Control - DAB Aerial - Strut Brace - De-badged - Flip Key Fob - Air Freshener
To Do: Trip Computer/Stalk Button - Renew Air Freshener
Hi Dave, apparently i can't have one of those, my key have only one button ( pre 2001 ) it's the rubber type key fob, wich locks and unlocks on same button, to bad
, i'll try look here at some locksmith if they can arrange me something, even if i pay a lot for it...
- NineWhileNine
- 1.6 8v
Hi RayneR
That's too bad.
I knew there are at least 2 fob types but I am not aware of the year when they changed.
Hope you get one sorted.
Dave
That's too bad.
Dave
1987 Fiat X1/9
