Does anyone know if there should be an abs collar (teeth) on the 406 front n/s wheel?
my abs light is on and its my first mot with the car soon so need to get to the bottom of it, there is no collar there at the moment.
i am aware they can be bought seperate from the cv joint online.
its a 02 hdi saloon 110
thanks in advance!
ABS Teeth
Re: ABS Teeth
All 4 wheels each have a ring
The rears are part of the hub assembly, and the fronts are on the cv joint
1999 D8.5 HDi GLX - Sold
Bring back my 406
- 406hdi02saloon
Re: ABS Teeth
thanks.
so, i presume, the ring on my n/s front has snapped off, or the original cv joint has been replaced with a non abs version before i bought the car?
in any case i found these abs collars on ebay:
http://www.ebay.co.uk/itm/110756504705? ... 1438.l2649
i always thought the cv joint had the teeth cast into them? would it be wise to replace the whole joint or just buy one of these collars?
thanks again!
thanks again!
Re: ABS Teeth
It seems like none of them are, not even the rear hubs. I can tell you how many teeth the rears have but not the fronts
There's a "how to" over on the coupé club for fitting the rings without having to remove the driveshafts. There are pictures, it is a D9 and the rings have, hold on, 1, 2, 3... 48 teeth, just like the rears
- carpingtaz
Re: ABS Teeth
I just had this problem abs light on just before the mot found the ring had split just came off in my hand406hdi02saloon wrote:thanks.
thanks again!
because it was so close to the mot i just took it to the garage and had a new cv joint put on lot less
hassle job done.
2001 2.0 HDI 110 Estate
Re: ABS Teeth
steve_earwig wrote:It seems like none of them are, not even the rear hubs. I can tell you how many teeth the rears have but not the fronts![]()
Do yo have a link to this as my d9 needs one on the drivers side.
"I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me. Your car...is your story. So don't let someone else write the book." - Moog
Re: ABS Teeth
http://www.peugeot406coupe.com/phpBB3/v ... 45&t=36860
You'll need to register/log in to see it though.
