PP2000?
- Bailes1992
PP2000?
http://www.ebay.co.uk/itm/New-Lexia-3-D ... 3a71fc7b1a
Can I use this to activate cruise control?
Bailes.
Bailes.
Re: PP2000?
Sam, that's the right kit, but I don't know if your Siemens ecu will support it.
Even if it does, you need to check you have at least the wiring for the clutch & brake switches
- Bailes1992
Re: PP2000?
Just bought it
307 with Siemens ECU don't have any issues.
The cruise control stalk is less than £15 straight from the dealers so going to order one tommorow.
Then hope for the best
Also apprently with Com2000 you dont need to add extra pedal switches either
Re: PP2000?
If they were fitted, you could be in luck.Bailes1992 wrote:Also apprently with Com2000 you dont need to add extra pedal switches either
It will need enabling in the BSI, possibly engine ecu too.
Good luck.
- Bailes1992
Re: PP2000?
There is switched on both pedals. Ones red and ones blue IIRC.Doggy wrote:If they were fitted, you could be in luck.Bailes1992 wrote:Also apprently with Com2000 you dont need to add extra pedal switches either
Good luck.
I'l give it ago and see what happens
Wanted PP anyway, so worse case scenario I have to sell the Cruise control stalk which go for £50+ on ebay
Re: PP2000?
Could well be OK - if it doesn't work straight away, it's still worth persevering with, IMO. I'd hate to be without it.
Re: PP2000?
In 406 semi mux, i have 2 switchs on break pedal and 1 switch on clutch pedal. An needed to activate function on ecu.(Needed to replace ecu since my original one didn't had any extra features on it)
Re: PP2000?
Let me know how you get on with it as i'm toying with the idea of buying one but am a bit weary of plugging in anything to the carBailes1992 wrote:Just bought it
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
- Bailes1992
Re: PP2000?
I always cruise at 65 as I find thats a nice speed that you can quickly overtake the lorries and get back in the inside lane.Doggy wrote:Could well be OK - if it doesn't work straight away, it's still worth persevering with, IMO. I'd hate to be without it.
Cruise control would make motorway driving 10x nicer!
Where exactley do I need to activate everything?
Re: PP2000?
If it is COM2000 stalk, then you need activation on BSI and ECU. But if i were you i would check if you have the sensors on brake and clutch pedal before you fancy with playing with PP2000, because you will end up buying something that it will not help you on what you want to do.Bailes1992 wrote:I always cruise at 65 as I find thats a nice speed that you can quickly overtake the lorries and get back in the inside lane.Doggy wrote:Could well be OK - if it doesn't work straight away, it's still worth persevering with, IMO. I'd hate to be without it.
- Bailes1992
Re: PP2000?
From what I read, Com2000 cars don't need any extra sensors. Just the stalk and activate.
Re: PP2000?
Then go for it, just hope that you have the remote programming feature on your ecu, or you will end up needing a new ecu like i did
Re: PP2000?
Probably easiest to wait until you've got PP2000 up & running as it'll make much more sense then.Bailes1992 wrote:Where exactley do I need to activate everything?
Happy to talk you through it, if you want.
- Bailes1992
Re: PP2000?
I'l get everything and have a play. If I can't get it working I'l prob get hold of youDoggy wrote:Probably easiest to wait until you've got PP2000 up & running as it'll make much more sense then.Bailes1992 wrote:Where exactley do I need to activate everything?
Am I right in thinking there is no light on the dash to tell you when cruise control is on?
Re: PP2000?
There's no light on the dash for cruise control which i find a bit strange.
