I noticed a few weeks ago that my indicators don't always tick, the light on the dash still flashes as it should and I'm fairly sure the indicators are still flashing as they should (or a lot of people have a death wish!) Sometimes I start indicating and it doesn't tick at first but a short while later it will start ticking, other times it won't tick at all and other times it ticks right from the start.
I know that the ticking is usually the relay, so if it's not ticking it's not flashing, but is that not the case on an '03 406? I think it would be odd if the tick was added just so you can hear when your indicators are on! Is the indicator relay a separate relay or is it in the bsi?
Indicators don't always tick!
Re: Indicators don't always tick!
Yep, it's in the BSI, the tick is made by a small speaker in the COM2000
So a lack of ticking isn't anything to be too concerned about! Seems odd to have the ticking added artificially!
But people expect to hear it. I don't even think it's a legal requirement.
Its not a Mot fail,
aslong as the indicator light flashes on the dash, dont 'worry about it,
RobTurbo,
I have had exactly the same fault on my 2004 HDi 90, it got worse & worse until they hardly ever 'ticked', although the indicator system functioned perfectly.
Wanging the indicator stalk about in all directions, making the headlights flash etc every day has apparently fixed it.
Lazy contacts in the switch base somewhere?
It's all working every day now.
2004 HDi (90) 'S' Estate, (was) just 62'000 OAP miles, now 108'000
1973 Spitfire 1500 - ENGINE JUST EXPIRED!
2005 206 1.4 SW (Wifeys) - Great little motor!
When I first got the car it had the floppy indicator problem, I fixed it by pulling the com2000 apart and stretching the spring, I think I stretched it a bit too much though because it's hard to flash the lights now, by the time you've applied enough force to move it, it goes straight past flash and turns the main beam on (if the lights are on of course!) so it may be time to strip it down again to both fix the headlight flash and check contacts on the indicators.
