Lost my V6....!
Lost my V6....!
Haven't been on here long but I just noticed under my avatar that apparently I drive a 1.6 8v motor!
What's that mean? Have I won a prize??!!
Re: Lost my V6....!
That's not your car, that's you that is
Most forums have a status that improves as you post more (usually from things like "Newby" and "arrived on last train" to "Post Whore" and "Can't Bloody Stop Talking"), ours goes through the engine sizes of the 406. I'm sure somebody could change your status to "Fresh Meat" should you so desire...
If you put your car in under your profile it'll still be there.
Re: Lost my V6....!
Or Z-Duck taped intake.steve_earwig wrote: I'm sure somebody could change your status to "Fresh Meat" should you so desire... :
Re: Lost my V6....!
Ah yes, the trench periscope
Re: Lost my V6....!
It bl**dy works though!
Ta for the explanation...
UP Periscope.....
UP Periscope.....
- Bailes1992
Re: Lost my V6....!
Makes me miss my V6
Re: Lost my V6....!
Yes, 'tis a smooth motor.
PS How many thousands of posts does it take to get 3.0 V6, my proper engine status??!!
Ah ok.Didn't know that. Just shows how many forums I'm not on.......steve_earwig wrote:Most forums have a status that improves as you post more
- Bailes1992
Re: Lost my V6....!
1000 I think.
I had mine for very brief spell. It was a GTX Auto.
I paid next to nothing for it. Had 194k on it with a recent 'cambelt' change. I later found out when the tensioner failed that they really had only changed the cambelt
Re: Lost my V6....!
When I did mine at 78,000, you would have thought that the belt that came off was brand new! It was in perfect condition and the only difference I could see was that the white printing on the smooth side had worn off. The rollers and tensioner were in similar condition too. Kind of reassuring on the one hand , but frustrating in a way on the other because it makes it seem what you've spent all day doing, a waste of time!!(which it isn't btw!)
I changed the whole lot anyway. £320 from dealer for the kit. Belt two rollers and the tensioner assembly.
Re: Lost my V6....!
In all seriousness is there a way to fit a land rover deep water exploration snorkly thingymagiggy to ours?
Without the use of a bonnet scoop?... There was a hint of seriousness in there i promise, Welcome to the forum Markw.
Re: Lost my V6....!
Don't worry 'bout it Scotty, all the jokes about that B&Q ducting have been thick and fast on the Coupe forum.
Once you get past the fact you're putting bits of kitchen under your bonnet, you'll be fine!
