There are 3 boxes in there, does anyone know which is which?
I believe myself the top one (seen without a box on this picture) is the slow fan relay.
I also believe the bottom green one is the fast fan relay.
Question is, what is the blue one?
I replaced the slow fan relay, £6 @ Peugeot.
Fan is still failing to fire up with PP.
There was a small 'nick' in the wires, I say nick, no wire was shown but the plastic insulation was crimped almost.
Bailies has already suggested to cut the wire and solder it back in, going to try and avoid doing that...
Another question:
PP refer to the fans as Fan 1 and Fan 2 (Fan 2 being the slow speed one). Are there really two fans? If so, where is the other hiding?
Thanks in advance.......
