Hi all
Was wondering if anyone can help me please? My brother has a 2000 x 406 110hdi and the instrument is not getting any communication from BSI. I have swapped the BSI over with one I bought for my car when I was having all my problems, but it still won't work? Also, when the key is taken out of the ignition the fan and time and date display stay illuminated....this lasts about a minute or so then drops out for a few seconds then comes back on? The lights,indicators,wipers etc are all working but not showing up on the instrument cluster as well as speedo and other dials down? I put it on planet and it's just saying "no communication between BSI and the ecus of comfort circuit" , no communication with instrument panel, A/C and display. It also said something about DATA BAR LIVE?.
Any ideas guys???
406 HDI X INSTRUMENT FAILURE
Re: 406 HDI X INSTRUMENT FAILURE
you cant just swap over the bsi, you need the bsi and also the matching ecu that goes with it as well as the transponder from the key all from the donor car, unless the bsi you have has been virginised...ie an e new one.
Sorry, should have mentioned that it was everything I swapped over...BSI,ecu,transponder chip and ignition ring
were are you based?
In Liverpool mate
ALL FIXED
Turns out the problem was there had been water ingress in the back offside light and there was a connector block sitting in a puddle of water......hope info can help someone else out
