HELP!! Unsolvable electrical problem
Hi, I'm posting on behalf of a work colleague as he doesn't have a pc (sorry,he's old!)
He's currently faced with scrapping a loveley 406 Executive W reg as it has developed an electrical fault which means the hazards won't work and several warning lights have come up on the dash (but no faults are there to cause them to light up!). A mechanic friend and a garage have both looked at it and diagnosed the problem as a moisture based corrosion of three multi plug connectors down by the drivers seat area. They've tried to bypass the plugs but have now given up after spending many hours looking at it so he is faced with either taking it to a Peugeot dealer for a re-wire (probably not economical considering the value of the car?) or scrapping it as the MOT has just run out
I said I'd see if I could find any info on the 'net so here I am. Hopefully someone has come across this problem before and can give some advice
Oh, he did mention that the wires are not very well colour-coded so diagnosis/repair is tricky to say the least!!
Thanks for looking
Jim
Thanks for looking
Jim
Re: HELP!! Unsolvable electrical problem
Hello. Yes, it's happened a few times, it can usually be sorted out with patience (and if it's not been messed up too much by meddling kids...) Have a look at this: viewtopic.php?f=10&t=12118&p=107150&hilit=crazy#p107150
It may (or may not) help to know Peugeot don't "do" colour codes, the wires are actually numbered near the connectors.
I actually thought a 2000 (W reg, yes? I'm a bit out of touch with that sort of thing) would be too early for this (ahem) issue. Any chance you could post the chassis number?
I've had the "issue" with a W reg 406
W is 2000 reg.
W is 2000 reg.
Ah, that's that theory out the window then
X Reg 2000 do it as well mine got soaked last winter and every light on the dash went mad fuel gauge read full all the time etc etc
great, thanks chaps, the thread in the link sounds and looks like that's the solution to his problem, I'll try and explain it to him!
An independent auto sparky would be a MUCH better option than a dealer. The dealer solution to this would be to replace both (very expensive) harnesses - major job (complete strip-down of the interior including dashboard removal I think) with major labour costs - several times the value of the car
Yes, that's what he's been advised to do by the garage he took it to!!
I've told him about the clean up fix but he informed me today the connectors were that bad they were cut off so now he's asking if we can get hold of that section of the wiring diagram so does anyone have it or can point me in the general direction of where I can find it please?
Jim
Jim
So all he has now are bunches of wires, brilliant
Trouble is there are no colour codes, without the wire codes the only way of doing it was to carefully pick the connectors apart wire by wire.
Yeh, soinds like a right nightmare!!! I haven't seen it for myself but that's what he told me anyhow!!
I've found this http://peugeot.mainspot.net/wiring406/p8c.shtml#5 but that can't be the complete wiring diagram surely (I'm no electrical expert!)
As far as I can make out these are the connectors under the fuse panel:
Not where I was expecting to see them but I can't see anything else that looks likely.
For which connectors this is the diagram
Without the chassis number I've had to make a lot of guesses about the car but this will be close. It'll be worthless without the codes anyway
Thanks Steve, that's really helpful
