The charging output is 1A but some people on the internetz say you need 2A for modern i-phones and sh*t?
http://www.ukelectricalsupplies.com/dou ... -white.htm
The ones that catch fire?steve_earwig wrote:Stick with the plug-in jobbies
The ones which you can see and can switch off and unplug.Welly wrote:The ones that catch fire?steve_earwig wrote:Stick with the plug-in jobbies![]()
Pah, a mere formality considering the sort of crap they usually pass (and not necessarily from their bottoms). They did actually find a drastic and dangerous fault this time - one of the side light bulbs had blownWelly wrote: Good luck wiv the MOT-type man!
Don't beat yourself up, first of all the oil must want to changeWelly wrote:It should have an oil change, if I can be bothered..........
