Map sensor vacuum pipe
Matcoupe80
Post by Matcoupe80 »
Just a quick question, is the vacuum pipe that connects the map sensor to the intercooler the same diameter at each end? The reason I ask is that it feels like a larger diameter on the intercooler side, it maybe due to oil contamination swelling the rubber hose!! Just thought I would check before I disturb it.
jonsowman
Re: Map sensor vacuum pipe
Post by jonsowman »
It certainly has different diameters on the 2.2 HDi, so probably on the 2.0 110 HDi too...
Same sensor on both engines IIRC
fattail95
Post by fattail95 »
Different diameters on my 110!
Matcoupe80
Thanks chaps, I thought as much. .
