Supply sensors, EGR
Supply sensors, EGR
Hello
This same car with another issue
1. Position EGR solenoid valve : permanent fault, short circuit to earth
2. Supply to sensors short circuit to earth
I replaced the EGR with new EGR, and i actuated it, but still is showing EGR fault, and the rpm keeps fluctuating above 1000(despite i change the injector mouth i.e motorizee) ,
Meanwhile i don't what supply sensors means?
Any suggestions?
I attached the faults below
Any suggestions?
Re: Supply sensors, EGR
As per your other post, it is possible the power supply for the solenoid valves on the bulkhead is missing or has a poor connection. Without access to the diagrams its not easy to trace these faults but I would suggest taking precautions for disconnecting the battery then testing all the fuses in the engine fusebox.
I seem to recall an old post about an improvement made to the earthing for some of the engine sensors to eliminate something of this sort, anyone remember or have a clue how to find it?
Ok.. Lemme check the fuses.. But today I tested the Continuity of each and every wire of cylinder reference sensor, EGR, TPS, inlet manifold sensor, throttle potentiometer all down to ECU.. All the wires are continuous..
Phew.. The car is full mux.. Let check the fuses
I tested a different ecu and bsi and everything worked fine.. It means my ecu is bad, i need to replace it
Have you checked the actual obd2 port on your car?
Is one of the holes slightly damaged or corroded?
The port is ok.. Like I said i tried another bsi and ecu on the car.. Then scanned.. All fault gone.. So i concluded that the ecu is bad.. Now i have to buy used bsi ecu and key..
Anu suggestions where i can get cheap working types?
Oh I see - I thought you tested your PP2000 on a different car - my apologies
After swapping both the BSI and the engine ECU, did you actually start the engine?
Many faults will only appear while the engine is running.
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 710.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
Yes i did.. Car started
No fault..
I wish I could buy complete system like that..
No fault..
