Avgasandy
Posts: 21 Joined: Sat Jun 30, 2007 1:29 pm
Post
by Avgasandy » Sat Jun 30, 2007 7:16 pm
Hi just been to do weekly shop and the airbag light has started to flash any ideas as to what the problem may be?
Thanks for looking
Foghorn Leghorn
Posts: 282 Joined: Wed Aug 17, 2005 10:30 pm
Post
by Foghorn Leghorn » Sat Jun 30, 2007 7:30 pm
Check the orange connectors under the two front seats, these have a tendency to work apart, especially if you wedge anything under the seats.
Fog
wes1001
Posts: 177 Joined: Tue Dec 19, 2006 9:10 am
Location: Sticky out bit, right on the tip of Kent, practically in the channel !!
Post
by wes1001 » Sat Jun 30, 2007 8:20 pm
Yep what Foggy said. Cut the connectors off and solder or wrap wires together for a permanent fix and no it won't set the airbags off
xplosiv
Posts: 322 Joined: Wed Aug 16, 2006 12:40 pm
Post
by xplosiv » Sun Jul 01, 2007 2:22 am
Take the battery off first or you maybe in for a suprise airbag test
ANdy
wes1001
Post
by wes1001 » Sun Jul 01, 2007 10:25 am
xplosiv wrote: Take the battery off first or you maybe in for a suprise airbag test
ANdy
Nope you don't need to do that - has nothing to do with the firing mechanism
Avgasandy
Post
by Avgasandy » Sun Jul 01, 2007 4:59 pm
Hi thanks for all your replys did as you said gave connections under the seat a wiggle and done 100 miles today and no sign of the airbag light apart from when starting the car.
Cheers all
dervpower
2.2 16v
Posts: 238 Joined: Tue Oct 24, 2006 10:10 pm
Post
by dervpower » Sun Jul 01, 2007 8:04 pm
ive got the same problem which ive tried to rectify several times but its only ever been temporary so i really need to rejoin the wires somehow any ideas and ive also always disconnected the battery is this not a wise precaution??
dervpower
2.2 16v
Post
by dervpower » Fri Jul 06, 2007 7:03 pm
Foghorn Leghorn
Post
by Foghorn Leghorn » Fri Jul 06, 2007 10:37 pm
Only thing I can suggest is thoroughly cleaning the connectors with a contact cleaner, the airbag light is one problem I've not had with my car so I'm not sure what else you could do.
Fog
wes1001
Post
by wes1001 » Sat Jul 07, 2007 12:30 pm
dervpower wrote: ive got the same problem which ive tried to rectify several times but its only ever been temporary so i really need to rejoin the wires somehow any ideas and ive also always disconnected the battery is this not a wise precaution??
See my first post
dervpower
2.2 16v
Post
by dervpower » Sun Jul 08, 2007 11:39 am
do you know which connector gives the problems?
wes1001
Post
by wes1001 » Sun Jul 08, 2007 11:43 am
9 times out of 10 it's the orange one under both seats which controls the seat belt pre tensioners.
