wiper blades
wiper blades
Does anyone know of a simple way of replacing the wiper blades on a rapier, i need to replace the blades. I have set the wipers so they sitting up on the windscreen but cannot get the arms to come backwards to remove the blades and it's not very easy to remove the arm, i removed the 16mm bolt but the arm would not come off the bolt.
- jameslxdt
Re: wiper blades
turn the wipers on and when they get to the highest point on the windscreen, switch the ingnition off, this will give you maximum leverage which still aint much unfortunatley, but its the only way to do it
Re: wiper blades
You shouldn't need to take the arms off anyways, there should be a part you can move round on the clips. Always a bit fiddly...
Re: wiper blades
you normally need to pull the blade slightly away from window then hold the arm and push the metal bit on the blade down back towards the screen. it should "pop" then you slide the clip and the blade out from the arm.
last time i tried i spent 20 mins and broke one clip (and a knuckle or two) before i remembered how they fitted
1997 Honda Prelude 2.2 VTi
Re: wiper blades
I posted on here when i tried to take mine off.
I eventually manage to do it, but yeah it is a complete bastard to do.
- DaiRees
- Site Admin
Re: wiper blades
Naaahhh, they're not that bad to do. There are a few different types, once you understand the way your ones work they're pretty straightforward really.
- Site Admin & Mad Biker!
Re: wiper blades
But the odds are you will skin a knuckle or two
