Ticking
Ticking
Hi all,I have a quick question.
I noticed yesterday morning after work my 51 plate 1.8 406 was making a random ticking or clicking noise from under or around the ECU.I put it down to the sub zero temperature and went off to bed.Ive just got home from work this morning and its doing it again.
Can anyone shed any light as to what it could be?
Ive had a quick look as best I can without it being on ramps to look underneath and cant see anything or precisely pinpoint where the noise is coming from.
TIA,Iain.
TIA,Iain.
407 GT multimedia
Re: Ticking
Hi,
Do you mean an electrical ticking? or when the engine's running?
This will sound bizare but came up on here ages ago (thanks to supafrisk) and it seems some ecu's tick/click and it can be solved by stopping, remove key, turn key through 180degs and put back in! bizare? yes - but she and her mechanic swore to it.
Re: Ticking
Its while the engines running mate.Kind of a tick tick tick tick noise quite quick.Its definatley in the region of the ECU box infact I put my ear on it and it sounded like it was coming from it.I hope somethings not goosed!
407 GT multimedia
Re: Ticking
Daft question, but are you sure it's not one of your injectors?
Re: Ticking
Good point m, could be the injector pulse width due to the cold weather.
He could try the James FAQ thing of disconnecting the Lambda for a bit to see if the noise changes?
- Site Admin & Mad Biker!
Re: Ticking
Mine does it sometimes. It sounds like the solenoid in the idle air valve going ape; I'll have to unplug it the next time it happens to check.
It's working fine so I'm not that bothered.
Re: Ticking
To be honest as much as I like the car (had it 2 years so it must be ok) I wouldnt be surprised if its something expensive.mjb wrote:Daft question, but are you sure it's not one of your injectors?
Its just another thing to go on the list along with a random rattle 3 mechanics cant find on the engine,a loud clonk when you start it or change down to second and just a general feeling of tiredness and fragility.Its a 51 with only 69k on it but it just feels worn out.Its absolutly babied,services every 7/8k,just had the cambelt done,gets washed atleast once a week and detailed once a month.Im just tired of the constant clonks and clicks making me think whats going to go wrong next!
407 GT multimedia
Re: Ticking
I've been living like that for 3 years406Iain wrote:Im just tired of the constant clonks and clicks making me think whats going to go wrong next!
Re: Ticking
it's part of the fun...
Re: Ticking
Well shes going in on Friday to try and sort the clonking.I think its an engine mount but the geezers going to have a look for me.Other stuff like interior rattles and whatnot Im going to eventually locate and fix in the new year when the better weather arrives (if it ever does).
407 GT multimedia
Re: Ticking
WOW! er, good luck with them then406Iain wrote:Other stuff like interior rattles and whatnot Im going to eventually locate and fix in the new year
My car seems to make a "new" interior rattle or squeek every other day! since having the engine mount done I've got a new rattle behind the binnacle which rattles in time to certain engine revs...nice
Re: Ticking
I had a rattle coming from the overhead console, all I had to do was touch it with a finger and it went but you can't exactly drive it like that. I tried packing it out with packing foam to no avail so eventually I took it to pieces, tightened up the switches, tightened up the screws holding the circuit board in, hot glue gunned the sunroof switch and put dabs on the corners of the clear plastic. When I put it back it was exactly the same
Re: Ticking
You said what now?steve_earwig wrote:sunroof
Re: Ticking
Sunroof. Works too
- DaiRees
- Site Admin
Re: Ticking
Yeah and mine Wiggy
Ain't ya got one Welly??
