speedos
dantae
speedos
Post by dantae »
hi guys can any one tell me if i can use a set off clocks that are the same as the ones in my 6 tubby exutive, thay look the same in every way but have diff part numbers thanks
Re: speedos
You could look it up on Service Box
dantae
Re: speedos
Post by dantae »
tryed that, i could not work it out :? :? :? :? :? :?
Re: speedos
How about if you post both numbers and I'll tell you if they're the same?
dantae
Re: speedos
Post by dantae »
ok here are the numbers, first the one in the car, 9628535980L, and the replacement one is 9628536180L. thanks
Re: speedos
Should work fine; I put a set from a 2l GLX on my old 1.8 lx.
Do bear in mind that you'll lose the correct mileage for the car though!
dantae
Re: speedos
Post by dantae »
ok thanks guys will fitt it as soon as i can, i did all the soldering on the board but it still dont work right, and i cant find a black box behind the glove box that controls the speedo
Re: speedos
Don't know if this is true, but I did hear that the mileage total is stored in the clocks & the ecu. (I think the idea is it 'restrore' the original mileage if you put a new set on). It seems this can lead to it adding the two together if you fit a used set :shock:
Can't prove this is the case but I'd advise checking unless you don't care what the total is, or you're trying to outdo bangernom1cs :roll:
Re: speedos
dogslife wrote:Don't know if this is true, but I did hear that the mileage total is stored in the clocks & the ecu
Not on D8's as far as I know (well, through personal experience anyway!)
Re: speedos
You're probably right - relates to a D9 GTX I almost bought.....
Re: speedos
It is a D9 thing. The mileage is stored in the display and the BSI
dantae
Re: speedos
Post by dantae »
not too worried about the milage, just want to see what speed im doing :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
