Does the stock clarion tape/cd combo use a code?
averagejo
Post by averagejo »
hi,
was thinking about disconnecting the battery for half an hour to try and clear any codes the ecu has stored up but i wasnt given a code for the stock clarion tape/cd combo unit - does it have one? and if i dont have it how can i get it????
thanks
dan
406 GLX D9 2001 2.0l 16v EW10J4
Re: Does the stock clarion tape/cd combo use a code?
If your car is a D9 (1999 onwards) then the radio is kind of 'logged' to the car via the BSi unit and does not have a code to input as such.
You will not be able to use the radio in another 406 wthout having it 'coded' to the car.
Disconnecting the battery will not effect the radio as it is.
MartinV6
Post by MartinV6 »
My 98 D8 saloon needs a code. Strangely though, my 99 D8 JBL'd coupe does not (though admittedly they are different OEM head units).
I would have thought Peugeot could supply you with the head unit code, though doubtless they would want £20 for the priveledge.
Martin.
98 V6 man 4dr - 103k miles
plus some bikes and an 80s 335i cabrio.
averagejo
Post by averagejo »
Welton wrote:If your car is a D9 (1999 onwards) then the radio is kind of 'logged' to the car via the BSi unit and does not have a code to input as such.
fantastic, thats the news i was hoping for :)
thanks
dan
eoin27
The Irish 406 addict
Post by eoin27 »
Disconnecting the ECU for half an hour won't clear any codes. You need to do this via the OBD port
averagejo
Post by averagejo »
thanks for the info eoin
dan
alladdin
Post by alladdin »
does anyone have more info on changing the code for a different car ?
If you're on about a D9 you'll have to take it to a dealer for re-coding. It's not something you can DIY.
