I've found that the buzzer located on the rear side of the instument cluster has been been 'manually disabled' by one of the previous owners beyond repair (long story why i think they did)
the one i have is the same as this:
and an ebay listing said the part number for a one on a listing is 6101pp
but when i look at service box for my vin VF38BRFNAxxxxxxxx it shows this cluster:
and part number 6104 W3
do i have the wrong instrument cluster in the car??? also if i do buy a second hand one off ebay etc is the milage stored within the bsi or something or will a replacement show up the donor cars milage???
Either Service Box is wrong or someone's replaced your dials at some point (the same butcher that broke the buzzer?) I think the latter as it would be odd for a GLX to only have 4 dials.
Someone please correct me but I think the miles are stored on both BSI and the dials and it'll add the two together (off for a search...)
oooooooook, the plot thickens - can anyone confirm? anyone with a glx out there?
if it helps it has 2 connectors that plug into it, one white and one black.
also, is that the right part number for the 5 dial set that i managed to pull off service box?
the 'butcher' also removed 12 of the instrument panel bulbs - one of them just happened to be the cat converter warning light - which just so happened to be causing my anti-pollution fault..... i suspect that also maybe why the buzzer was broken? does it sound off when there is a problem???
Ah, wrong again I thought my D9 was pretty much poverty spec but it has 5 dials and chrome surrounds Do us a favour Puggy, go into Service Box and see what dials it says.
There's no point fitting an oil temperature gauge if there's no sender...
steve_earwig wrote:There's no point fitting an oil temperature gauge if there's no sender...
I've changed my thinking. my car has been recording trip info to itself for the last 9 years and then i put in a trip comp I have no doubt at all that a five gauge cluster would work. i'm a betting man too
