Ladies and gentlemen, I present for your consideration the Wartsila-Sulzer RTA96-C slow-speed two stroke:
- Available in 6 to 14 cylinder straight configurations
14-cylinder flavour weighs in a 2300 tonnes and is five decks high
Said 14-cylinder engine outputs up to 84.42 MW / 114,800 bhp
960 mm / 37.79 inch bore, 2500 mm / 98.42 inch stroke
You can just about make out the guys working around it:
Installing the crank bearings:
And the shaft itself:
The cylinder head 'deck' - yes, those studs are twice the height of the guy installing them ^_^
Let the
