abs
abs
Hi i am a new owner of a 406 hdi executive.I have had the car only 4 weeks and already the clutch has needed doing!now the abs light is on and it has taken me a week to find that the drivers drive shaft is a non abs one! As money is running out on this car I am going to fit a second hand shaft .Can anyont tell me if driveshafts for all models are the same as there is a 406 in the local scrappy but its a different diesel engine to mine?
Re: abs
Hi there
I would have thought the 2.1td's drive shafts would be the same but apparently not
Are you sure it's not just missing the toothed ring? They sometimes crack due to rust building up behind them, if so then there's a guy selling just the rings on ebay.
Re: abs
compare the other side?
