abs
rallyman
abs
Post by rallyman »
Hi i am a new owner of a 406 hdi executive.I have had the car only 4 weeks and already the clutch has needed doing!now the abs light is on and it has taken me a week to find that the drivers drive shaft is a non abs one! As money is running out on this car I am going to fit a second hand shaft .Can anyont tell me if driveshafts for all models are the same as there is a 406 in the local scrappy but its a different diesel engine to mine?
Re: abs
Hi there :cheesy:
I would have thought the 2.1td's drive shafts would be the same but apparently not :( Are you sure it's not just missing the toothed ring? They sometimes crack due to rust building up behind them, if so then there's a guy selling just the rings on ebay.
rallyman
Re: abs
Post by rallyman »
I am just learning about 406's so how can I tell if the ring has broken off? as opposed to the wrong driveshaft fitted
Re: abs
compare the other side?
rallyman
Re: abs
Post by rallyman »
Good idea I will do that tomorrow assuming that the passenger side has a ring of course
rallyman
Re: abs
Post by rallyman »
yup the nearside has a ring on the driveshaft so I will have to order up and try and fit a ring to my driveshaft
rallyman
Re: abs
Post by rallyman »
I have now put a ring on the drive shaft but the dash is still showing abs fault.Do I need to get the dash message knocked off or do I have another abs problem?
