hello
NinoB
2.2 16v
hello
Post by NinoB »
pls where can i buy original nozzles and coil , plugs for my 406 d9? because my car always misfired every morning or when the engine is cold
Re: hello
Hi,
some more info might help.
what engine is it?
by coil..do you mean coil pack?
is engine management light on..?
NinoB
2.2 16v
Re: hello
Post by NinoB »
executive 201, ew10, d9, i changed plugs and nozzles several times, but the car is still doing misfire especially early morning if i started the car..then i read on internet that engine coils can cause misfire if they give unsatisfied voltage...well i check the engine sign using pp2k it shows misfire, so i cleared it..(note the plugs and nozzles i change aint brand new, its used)..is it possible to get original ones in ebay
Re: hello
By nozzles, do you mean injectors or the spark plug extensions?
NinoB
2.2 16v
Re: hello
Post by NinoB »
yea i changed both.. now i want to buy all original..including the engine coil
NinoB
2.2 16v
Re: hello
Post by NinoB »
any suggestion or even a link from ebay where i can original
NinoB
2.2 16v
Re: hello
Post by NinoB »
@steve..my English is bad thou..i mean injection nozzles
Re: hello
I was wondering but I checked your IP and it came back GB :?
So, which are you after, the coil pack or the injectors?
From the original question I think you want the coil pack, I had a quick look on ebay but they weren't much cheaper than Peugeot and it didn't say if they were original.
If you want to look the number for the coil pack is 597098. For the injectors it's 1984E2.
NinoB
2.2 16v
Re: hello
Post by NinoB »
Yea I want the coil pack and the injectors too..but I wish I can get original.. the numbers u gave is what I will use on my search in ebay or what?
Re: hello
Well yes. Either that or just use your engine - 406 2.0 coil pack/injector but I'd have thought you'd tried that already. The part number "should" get you OEM (should but it depends how honest the seller is)
NinoB
2.2 16v
Re: hello
Post by NinoB »
Okay
NinoB
2.2 16v
Re: hello
Post by NinoB »
hello
the seller was asking me about the OEM part number of my ignition coil, well i dont know how to get it, can someone help me please because i cant loose my engine cover,
any suggestions?
regards
NinoB
2.2 16v
Re: hello
Post by NinoB »
Hi Steve, pls any ideas?
Re: hello
You can't loose your engine cover? You can't loosen/remove it?
What's up with this?
steve_earwig wrote:the number for the coil pack is 597098.
Or are you after the manufacturer's part number? (i.e. Bosch or Siemens or whatever)
NinoB
2.2 16v
Re: hello
Post by NinoB »
The seller asked me about the OEM part number, which I guess it just a mere number, I thought there's a database that can rectify the part number if I provide my VIN? Which is easier.. something like dialogue box!!
Nevertheless, I will still open the cover and see if the part number is visible on top of the ignition coil.
