HID Lights
HID Lights
I was in a lexus there with factory fitted HID lights and i have never seen light like it they were great, is them aftermarket HID kits any good, and could the fog lights only be converted to HID
Re: HID Lights
The legality of retro-fittring them to 'reflector' style headlamps does the rounds regularly on car forums and although the manufacturers will tell you the lamps have 'shields' or whatever to make them suitable for reflectors they still are not the approved and testest light source which gained the certification of the headlamp design in the first place.
Primarily the reflector needs to be a 'projector' lens like a 406 coupe's and then it should have self-levelling adjustment and headlamp washers.
Many people have retro fitted these kits to reflector lenses and have sailed through MOT's and whatnot but the big sticking point is the insurance. If there was a bad accident (god forbid) they would look for anything for which they can apportion blaim and a 'converted' or unapproved headlamp will not look good.
I think the 406's headlamps are very good (much better than my Volvo) and if you fit Phillips Extreme Power H7's the light colour and distribution is fantastic.
mandelbug
Re: HID Lights
Post by mandelbug »
I did the conversion on my Nissan 200sx and the difference was phenominal. When I bought the pug I decided that I wanted a set for the pug but the prices have gone up since so not got round to it yet :)
no2lurch
Re: HID Lights
Post by no2lurch »
as i dont have much experience in 406's i have to ask.. are coupe headlights the same as non coupe lights?
Current car - Ph3 1.8 306
eoin27
The Irish 406 addict
Re: HID Lights
Post by eoin27 »
Woah, the coupe headlights are a totally different beast. They have a projector lens which most new saloons and exec cars with xenons have. The coupe is the perfect car to retrofit xenons to. (Except they don't have auto levelling).
The D9 saloons and estates have reflector lenses where the light is bounced off the chrome inside the headlamp and designed to point in a certain direction.
However, all 607s came with reflector headlamps and the later ones had xenons. So it is still not unusual for manufacturers to equip xenons to reflectors.
OFF TOPIC: Hi all, Ive been a bit absent for a while. Work blocked all forums with Websense :evil:
Re: HID Lights
Is there any retrofit projector lens lights for the saloon with a projector lens, but would HID lights slot into the fog lights because then they wouldn't have to be on all the time, only when they were really needed.
no2lurch
Re: HID Lights
Post by no2lurch »
eoin27 wrote:Woah, the coupe headlights are a totally different beast. They have a projector lens which most new saloons and exec cars with xenons have. The coupe is the perfect car to retrofit xenons to. (Except they don't have auto levelling).
as i am new to 406's, can you couple light units be made to fit the non coupe models?
eoin27
Re: HID Lights
Post by eoin27 »
Nope
Re: HID Lights
406executiveHDI wrote:Is there any retrofit projector lens lights for the saloon with a projector lens, but would HID lights slot into the fog lights because then they wouldn't have to be on all the time, only when they were really needed.
You really wouldn't want them that low - they'd be completely useless down there
Re: HID Lights
are all hid lights blue or is that just the ones that have been put on wrong
omega
Re: HID Lights
Post by omega »
have you thought of using led bulbs there are some on ebay about a fiver for 2 from hongkong and they e marked
mandelbug
Re: HID Lights
Post by mandelbug »
406executiveHDI wrote:are all hid lights blue or is that just the ones that have been put on wrong
That's down to the K rating. There are charts on the net showing the K rating and the colour of the light. From memory 4300k is white
Voltron
Re: HID Lights
Post by Voltron »
Differences reflector and projector based xenon conversion.
Projector headlight in coupe has a sharp cut-off. But it designed for halogen bulb optics. For real hid performance, D2S xenon projector must be use.
Re: HID Lights
does that mean its possible to get projector lens put into a saloon
Voltron
Re: HID Lights
Post by Voltron »
406executiveHDI wrote:does that mean its possible to get projector lens put into a saloon
Yes it's hard to fit but not impossible.
