Quick question...
If I buy a wing mirror, of a different coloured car - is it possible to pop off the plastic colour coded bit and use it on the new mirror?
Cheers,
Joel
Wing mirror
- DaiRees
Re: Wing mirror
It doesn't really "pop" but it does come off, I took the covers off the mirrors of my old D8 LX to paint them. It's easier to access the retaining tabs from inside the mirror once you have the glass out of the way
Re: Wing mirror
Cheers mate - trying to get a mirror with the temp sensor, wiring and plug!DaiRees wrote:It doesn't really "pop" but it does come off, I took the covers off the mirrors of my old D8 LX to paint them. It's easier to access the retaining tabs from inside the mirror once you have the glass out of the way
- Site Admin & Mad Biker!
Re: Wing mirror
You should swap over to 'leccy's Joel! If you need any advice I'll help where I can, you just need to source a GLX door card with the switches & the plugs, also the sockets that clip in the door pillar for the mirrors. You'll also gain heated mirrors!
Re: Wing mirror
I have leccys windows and mirrors - but no temp sensor in the wing mirror. The plug is there, but the loom isntteamster1975 wrote:You should swap over to 'leccy's Joel! If you need any advice I'll help where I can, you just need to source a GLX door card with the switches & the plugs, also the sockets that clip in the door pillar for the mirrors. You'll also gain heated mirrors!
Strange strange AU spec car
