My 98 2.1TD Executive
Bailes1992
Re: My 98 2.1TD Executive
Post by Bailes1992 »
I am so tempted to buy this off you and drop a 1.9TD in it but got no way of getting it home and if I do buy it I got no money for a new engine :(
HimBigChief
Post by HimBigChief »
Yeah got a feeling it's gonna be goosed, but for £20 for a belt I reckon it's worth a punt. Should be fun doing all that work in less than zero degrees in the snow though. :roll:
If it is knackered, then I will see what I can find, may get a 406 estate yet, but thinking something Forester/Quattro style 4wd and with LPG. That said, I would consider a HDI110 estate if I can find one cheap, then swap all my bits and pieces over.
Image Image
:shock: :shock:
so sorry to hear that mate, after all that hard work as well ....
i would like to put my name on a few things you have :oops:
BUT I REALLY HOPE IT WORKS WITH ANOTHER BELT ON IT FINGERS CROSSED FOR YOU MATE
sorry to hear the bad news, hope you can fix it. But from the experience of my 110 hdi id say go ahead and buy it, great car.
NollingtonHards
Post by NollingtonHards »
After reading about your belt snapping i became paranoid and checked when mine was last done. It was last done on 63000 miles, its now on 128,200 so im due a change pretty much now. I will be driving slow 'til early january when i have the funds to get it changed
Bailes1992
NollingtonHards wrote:After reading about your belt snapping i became paranoid and checked when mine was last done. It was last done on 63000 miles, its now on 128,200 so im due a change pretty much now. I will be driving slow 'til early january when i have the funds to get it changed
If a belts going to snap, dosent matter weather your engines doing 1000rpm or 6000rpm it will just snap :roll:
Best of luck with it chiefy - I vaguely remember someone else having a belt snap on a 2.1 about a year or so back and getting away with fairly minor stuff - here's hoping.
NollingtonHards
I'll take up praying then until its been changed
It still can't hurt treating it gently Nolly. :wink:
plod
Post by plod »
Fingers crossed for you bud 8)
1999 D8.5 HDi GLX - Sold :(
mark21TD
2.2 16v
Post by mark21TD »
The 2.1 can sometimes get away with a cambelt snapping, It will genrally just snap the rockers and leave the cam in one pice.
whip the cam cover off and have a look, just remember if the valves have gone it's an engine out job to get the head off.
406 2.1TD GLX estate
Xantia 1.9TD VSX estate
brew my own biodiesel
is it pushrod engines that are immune to this
Not really, unless they're very low compression. Perhaps you're thinking sidevalve :?
or is it vw aircooled and porsche engines, they didnt need a belt just your girlfriends bra.
The only belt on those drives the generator and the cooling fan, the cam is gear-driven so no possibility of valve damage if the belt goes.
Edit:
