Temperature display
Temperature display
Since i have disconnected the battery on my 96 1.9dt glx the temperature display is in farenheit im sure that it was in degrees c before does anyone know how to alter it back!
Thanks matt
Thanks matt
Petrol executive 2001 model Running on L.P.G
- Site Admin & Mad Biker!
Re: Temperature display
I'm sure that is set by a jumper on the side of the display! There's a post buried somewhere on this, I'll have a dig.
Edit: In fact one of the pins on the back needs earthing to display fahrenheit. If yours has done this after a battery disconnect it is probably shot.
a cheap solution . do what i did , mine is located in front of the speedo clocks
even the outside sensor fits through the access gromit under the carpet on the drivers side floor/bulkhead ...
http://www.amazon.co.uk/BACKLIT-INTERIO ... 586&sr=8-3
its in the menu when your setting the time with the left button.
- highlander
- PowerFlow Shill
The MFD on the D8 is completely different to the one on the D9
D8:
D9 (with SatNav):
D9 (without SatNav):
D8:
D9 (with SatNav):
i havent seen one of them fake wood veneers in quite some time.
whos car is that ? never seen the wood effect like that beforehighlander wrote:The MFD on the D8 is completely different to the one on the D9
D8:
- highlander
- PowerFlow Shill
Dunno, found it through a Google Images search
Personally, I think too much walnut = horrible
i think the wallnut thats there is enough but the added stuff i agree its yuck, the best thing to do to that part of the dash is paint it silver.
I know what you mean, we get so many off the tree here we don't know what to do with them, I couldn't even be bothered to pick any up this year.highlander wrote:Personally, I think too much walnut = horrible
a wallnut tree.
i like the walnut effect, on that pic it looks nice ,
i think it will be vinyl stuck on ive seen them on ebay
but i dont like it enuff to buy it and fiddle about cutting it and sticking it on
think i'll stick to the standard black effect
ive seen them wallnut stickers they really do look very stickerish. Spray paint is the best choice if you find the standard black a bit too discreet, but ideally it should be brushed aluminum.
