No power to radio?
Scaramanga
No power to radio?
Post by Scaramanga »
Hey all. Inherited the keys of a 406 exec estate last week (Y Plate) and been tasked by mother-in-law to get it up and running. It was a non-runner on the 29th Dec and after several jump starts, we realised the battery was finished. This was promptly replaced with a fresh one and the car cruised 300 miles to its new home. All the key components seem to be working though not tested the cruise control. What is puzzling me is that there appears to be no power to the Clarion radio unit and Auto-changer. Have checked the number 10 fuse and it's tickety boo. With the ignition turned on, not only will the radio not come on but I also cannot eject the autochanger. There are no messages suggesting the radio is looking for a code so I am somewhat baffled. Any suggestions?
Re: No power to radio?
Fuse 25, (passenger fusebox), may also be involved.
Do the other functions on your MFD work, (clock, trip computer, outside temp)?
have you had the radio out and checked the wires behind it ?
the person you inherited it may have had it out and not connected it back up,
worth a try mate ,
Scaramanga
Not tried fuse 25 but will check it tonight. All other MFD info seems to be working fine. When I managed to get the car running briefly prior to changing the battery, there was no life in the radio then either.
you really need another radio that you know works and test that in the car
then you can rule out sum problems,
It's a D9, which makes that sort of thing a tad more complicated.
why ?
my mate changed his radio over no problem and his is a D9 2000 reg
Needs converters and/or attacking with a pair of wire cutters on a D9. May as well use a light bulb to test for power.
well i changed his radio over from a standard clarion to a sony head unit,
it pluged direct in and worked perfect, no cutting involved
Fairy nuff.
Scaramanga
Ok, fuse 25 is alright too. Without getting hold of a replacement head unit, any other ideas?
if i remember rightly wen i bought my 406 2 years ago
the radio had a faulty power button ? maybe check that,
keep poking and prodding it for 5 mins see if that works,
with mine im sure you had to press it a certain way to make it power on
check the plug on the mfd,
My radio didnt work when igot the car and it was the plug that had worked loose some how in the mfd ,
its worth a check,
you can try another radio, they only bleep really loudly.
The changer should be run from the cabin fusebox, and have no connection to the BSI so it's either fuses (some of them are wired up in "interesting" ways - mine's upside down - so don't trust the handbook!), or their connectors have been unplugged
