Do it....
To entertain the kids tday I drove through a deep puddle at speed, on the way to swimming.
On start up I am met with "Battery charging fault" and battery discharge light.
Drive to the shops on the way home and call the fault diagnosis people...the AA.
He arrives very quickly and gives the alternator a clean bill of health as it is intermittently giving charge. It must be the "smart chargingsystem" he declares and I tottle home to think.
I phone John at PCR in Lancing first and they are open until 1430 so pop round there. The alternator is knackered - luckily 1 year and a month after being fitted whilst with the previous owner.
He has not got time to do it but sells me a replacement - £50.
Fitted it in 3 hrs and te only fiddly bit was pushing the tensioner with a 15mm spanner, holding the alternator and with your third hand putting in the bolt.
Easy job though.
His guidance on dropping drivers window and letting her rest before battery disconnect means I have no faults on start.
If your considering an Alternator change....
Peugeot 406 2.0 HDI (110bhp) Estate
Laquer free blue
2000 year car
normally 58.9MPG but 63MPG if solely for work run.
Laquer free blue
2000 year car
Re: If your considering an Alternator change....
So a nice bit of diagnosis by Alcoholics Anonymous
At least it's fixed now, and not too pricey.
Sounds like that "3 minute rule" thing again - viewtopic.php?f=10&t=13431EDWARD757 wrote:His guidance on dropping drivers window and letting her rest before battery disconnect means I have no faults on start.
i bet you wont drive through a puddle again
i never drive through big puddles fast, i always have this fear of water being sucked up into the air intake , that would be a nasty site
Indeed hydrauliced engine anyone?Gary406 wrote:i bet you wont drive through a puddle again![]()
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
i drove my suzuki like mad through big puddles, and it had no snorkel or fancy air filter assembly, just a pipe with a filter, and it never really caused a hydrauliced engine. Just a bit of backfiring.
You were lucky. It all depends on where the air intake is and how much water gets into the engine. A few drops will be fine. a couple of pints will blow it to bits.FarmerPug wrote:i drove my suzuki like mad through big puddles, and it had no snorkel or fancy air filter assembly, just a pipe with a filter, and it never really caused a hydrauliced engine. Just a bit of backfiring.
the 1.3 started to give a lot of backfiring trouble and i did blame the water, but it turned out to be really bad spark plugs, but the next time its getting a snorkel.
- plod
Mate drove a ford van ( fiesta derivitive ) through a ford and hydraulicly locked the engine
intake is quite low on them apparently
1999 D8.5 HDi GLX - Sold
Bring back my 406
does hydraloc actually do any longterm damage.
