Catalytic Converter,type approved.HDI
grasmere59
Post by grasmere59 »
I have been reading that if you have a 3/2001 onwards registered car you need to fit a "type approved" cat if you need to replace it at anytime,what would be the difference if you fitted a non "type approved" one as mine is a bit ropey and i have been offered a nearly new one from a 1999 hdi,it will physically fit but will affect the running of the car? As there is no Lambda sensor i can't see it affecting the engine management.Any ideas? :?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: Catalytic Converter,type approved.HDI
I fitted a "non-type approved" one to my HDI and it's ... OK. A bit louder than the original one with the whole but doesn't stink in the cabin and passed MOTs. There is no lambda sensor in diesels.
Although I have one fitted, I wouldn't recommend it due to it being louder! And illegal.
I've got an empty casing instead & it passes the MOT without problems. May have to replace it soon as I suspect my flexi section is leaking (again) :evil: , but I'm certainly not going to stump up for a type approved one.
leehdi
Post by leehdi »
Just de-cat it. You don't need them for the MOT.
Decat approx £50
New CAT approx £300 [for a good one]
You choose
leehdi wrote:You don't need them for the MOT.
Apparently you will from January :frown: - viewtopic.php?f=5&t=15575
Bailes1992
Post by Bailes1992 »
Get an empty case welded over the pipe, thats my plan :)
leehdi
Post by leehdi »
Depends on the MOT'er :wink:
