Springs
xplosiv
Springs
Post by xplosiv »
Hi,
Looking at my car on the flat it seems to lean slightly to the driver’s side (sorry I did ask this before but could not find the thread I started)
I checked the springs to see if they had snapped at the bottom, and as far as I can see they have not. The mechanic thinks it is because the car has had only one driver in it for years and may have cause the springs to remember the positions (so to speak), he must have been one fat bas*tard.
Neh way any other ideas?
Can I easily replace the springs at the back myself? (P.s I am rubbish at fixing anything mechanical)
Many Thanks for your help
Andy
NB; hope you all have a good weekend
Re: Springs
xplosiv wrote:fat bas*tard :arrowl: Most entertaining swear word error evAr
Any hoo, The fat f*cker (see I swear properly) I don't think is the answer, sure you might get a 5mm difference over the years on the drivers side but I would very carefully check the bottom of the springs like I did.
You've got to have the rear wheels off and check the very last bit of spring in the cup at the bottom mine was snapped off leaving about a 40mm long bit in the bottom.
xplosiv
Post by xplosiv »
LOL just noticed my error,
xplosiv
Post by xplosiv »
i will have a look on saturday as it is raining where i am, can i repplace the rear ones myself?
do i just jack it up and get two spring clamps, pull them off and swap them, or are they scewd into place
Many thanks,
Andy
dougspug
Post by dougspug »
had my car lowered ,the rear springs are a bastard to replace,its officially a 4 hour job,most of the rear suspension has to be dismantled.thats with a qualified mechanic 30 years and all necessary tools/equipment.
tux2006
Post by tux2006 »
is their any difference between the D8 and D9 rear suspension or is it all the same?
Assumptions are the mother of all F**k ups.
xplosiv
Post by xplosiv »
Hi,
Nope they are the same, if you have loads of cash (i have not good old student :cry: ) i would replace the two front springs as well. I got some german spings for mine (k something) they have a thick black plastic/rubber cover over the sping which stops it snapping again.
Just a heads up i had to get some new spring holdy things as well, as when my rear spring snapped it damaged the holdy thing (lol tech term s)
IMO you did it wrong (you did jack the car up :lol: ), i replaced both rear springs in 1 1/2hrs and cost £80 for the spings and £7.00 each for the holdy things
ANdy
tux2006
Post by tux2006 »
yep its shouldnt be that hard as long as you don't mess it up or break anything its pretty straightforward fitted 40mm drop springs + shoocks last week (the tie-rod came off in two bits tho so needed a new one) not all that impressed gna get a set of the spax 55mm springs when i have the cash
