why am i laughing?Bailes1992 wrote:Why is nothing simple. Walked 2 miles with a very heavy hub to motorfactors, got the bearing and walked a further mile to the garage to have it pressed in. Turned out to be the rear bearing instead of the front one. Another mile to motorfactors to make sure I get the right bearing. Then it turned out the driveflange on my new hub is f*cked so goto take off my old hub, take it to the garage so they can remove the drive flange on the old hub and fit it to my new one
At my witts end...
Re: At my witts end...
- Bailes1992
Cars off the road for a fortnight... ball joint pinch bolt is firmly welded into position.
Mobile mechanic can't get to me till the 2nd. Ahh well think of the money I'm saving
its a good job theres bad luck else you wouldnt have any luck at all.Bailes1992 wrote:Cars off the road for a fortnight... ball joint pinch bolt is firmly welded into position.
do you think you where a bad person in another life?
- Bailes1992
I think so, this bolt is an absolute twat!omega wrote:its a good job theres bad luck else you wouldnt have any luck at all.Bailes1992 wrote:Cars off the road for a fortnight... ball joint pinch bolt is firmly welded into position.
It's welded in position is such a way that the taper is stuck closed so I cant even force the ball joint out.
I have hit the bolt so hard trying to get it out it has squished and 'Bulbed'.
I have nackered the end of this bolt up so much I can no longer put the nut back on the end
I repeat, C4, detonator & since you didn't bend the dogmobile, maybe a timer too.
Keep soaking the bolt in Wd40 itwill come out,Bailes1992 wrote:I think so, this bolt is an absolute twat!omega wrote:its a good job theres bad luck else you wouldnt have any luck at all.Bailes1992 wrote:Cars off the road for a fortnight... ball joint pinch bolt is firmly welded into position.
ive had this problem on mondeos, where someones put the bolt in the wrong way,
if the bolts knackerd all ready - Put a solid bar against the edge of the thread and whack it with a Lump hammer,
Hang on a minute: iirc isnt the end of the bolt a Torques not a bolt type,. they are on mondeos not sure on the focus but irember some had to be twisted out they wouidnt tap out.
what is the end on the bolt is it torques or bolt head?
- Bailes1992
Only the end of the bolt has a thread on it. It should tap out but aint budging. May have another go tommorow. Worth getting a blow torch on it?lozz wrote:
And it's a Torx which I've pretty much rounded out
The hubs scrap anyway, tempted to just get a drill and drill the bastard out
Get a solid bar you can use as a punch and whack it it will go eventualy, dont give up keep trying
- Bailes1992
Drilled out the ball join punch bolt, hammered out the ball joint destorying it in the process and then quite happilly rounded off the strut pinch bolt...
Seriously? I aint cack handed, I got the one off the scrapped car EASY but this is taking the buiscuit!
- Bailes1992
Ended up replacing the lower arm. Sorted now
Excellent . ibet your glad its back on the road.
Also glad to see you didnt Give up on it .
- Bailes1992
Soo close to giving up though. God happy with the angle grinder. My Old hub ended up in about 5 different pieceslozz wrote:Excellent . ibet your glad its back on the road.![]()
are You a butcher ?Bailes1992 wrote:Soo close to giving up though. God happy with the angle grinder. My Old hub ended up in about 5 different pieceslozz wrote:Excellent . ibet your glad its back on the road.![]()
- Bailes1992
Would explain quite a lot if I was!lozz wrote:are You a butcher ?Bailes1992 wrote:Soo close to giving up though. God happy with the angle grinder. My Old hub ended up in about 5 different pieceslozz wrote:Excellent . ibet your glad its back on the road.![]()
Cars feeling really tight on one side now.
Unfortunatley I've skinted myself in the process. Going to have to wait till I start work before I can get the other sides lower arm sorted.
