clutch pedal,
roverv8
clutch pedal,
Post by roverv8 »
Hi,
have fitted the gearbox to pug, when i removed the box the pedal would only go down half way and no more, (i now know why) :shock: now i have fitted new clutch and box is back in vehicle but pedal has gone right to the floor ,is it just a case of bleeding or is there something else?
from what i could see i lined up the slave cylinder rod to the clutch fork so that should be ok,
iangt4
Re: clutch pedal,
Post by iangt4 »
providing the fork is attached to the release bearing, its just a case of bleeding the system mate :| :wink:
To rebuild the impossible is possible by making it become a passion..... Oct 2001 406 2.2HDi 16v Executive..... A work in progress :D
roverv8
Re: clutch pedal,
Post by roverv8 »
i hope so don`t fancy pulling it apart again, :shock:
Re: clutch pedal,
Remove the slave and shove your fingers in to see if the fork's either flapping about, or stuck in a sunk position.
It's quite possible the bearing's popped out of the pressure plate. It happened to me as a result of a failed bearing, so I needed to do all the work again :cry:
roverv8
Re: clutch pedal,
Post by roverv8 »
i have put my finger in the hole and can not move fork (good news) can`t see a bleed screew on slave cylinder how do i bleed it?
roverv8
Re: clutch pedal,
Post by roverv8 »
any one?? :shock:
roverv8
Re: clutch pedal,
Post by roverv8 »
some one please tell me this is a load of old rubbish,
clutch bleeding,
If it's the 2.1td 12v model it's a sealed system, the whole unit must be replaced (£198 for parts only) That includes pipes, master/slave cylinder & reservoir already made up with a "snap off" clip that breaks on first use of the pedal and starts the thing working. There is no bleed facility.
:shock:
Re: clutch pedal,
roverv8 wrote:some one please tell me this is a load of old rubbish,
clutch bleeding,
:shock:
Hi,
ive had a nosey on the "Google, tinterweb,
Theres Mention of BAck bleeding -them, dosent say much on how its done tho, :(
You might be best asking Jaspers, he may know a way of bleeding them,
Re: clutch pedal,
Theres some Guides, also Haynes Bible here,
might be worth alook,
linky
EDIT BY MJB - remove link to material of questionable legality
roverv8
Re: clutch pedal,
Post by roverv8 »
After playing with pedal last night pumping up and down the pedal seems to have come back today, :shock: how long for is anyones guess, :lol:
whats back bleeding?
roverv8
Re: clutch pedal,
Post by roverv8 »
well had a drive round tonight clutch pedal is a little soft but there's no crunching in to gear so it must be doing its job, :shock:
just want to say (as i don`t come on here very much) many thanks for all your help got me out of a corner, :mrgreen:
iangt4
Re: clutch pedal,
Post by iangt4 »
glad you got there !!! :D :D :D these cars are bloody great mileage munchers but i hate clutches and the electrics with a passion..... :roll:
roverv8
Re: clutch pedal,
Post by roverv8 »
iangt4 wrote:glad you got there !!! :D :D :D these cars are bloody great mileage munchers but i hate clutches and the electrics with a passion..... :roll:
well it seems there's a problem with pedal now its just been for mot but the pedal not clearing and its starting to crunch and shudder, dont tell me it needs a new clutch and slave set up? :evil:
Re: clutch pedal,
Presuming you've got a D8, you'll be wanting a complete replacement hydraulic system. Shouldn't be too hard to find one on ebay or a breakers yard
