2.1 TD cutting out after driving for about 5 mins
- CalamityJames
Hi all,
Bit of an odd one here, I've had the 406 running on veg now for a good couple of months with no problems, I change the fuel filter regularly (last done about 300 miles ago) but I ran into a very strange problem today.
It took quite a bit longer to start than usual (needed 3 rounds of the glow plugs) but once was running I assumed it was fine, however after I'd driven down the road and went to pull up to a set of traffic lights, the engine completely cut out as soon as I dipped the clutch, and it wouldn't restart no matter how many times I put the glow plugs on. Somehow moving it on the starter motor seemed to then get the engine to restart when I tried again, but before that it didn't even sound like it was trying to fire!
Has anyone got any suggestions as to what might be causing this? As I said, the fuel filter has been changed very recently. A bit panicked as I was supposed to be taking the car to Yorkshire this weekend!
Cheers,
James.
Edit: Also, to anyone who doesn't know, it's had a Bosch pump conversion
Cheers,
James.
Re: 2.1 TD cutting out after driving for about 5 mins
Strainer on the bottom of the fuel pick up (in the tank) full up with gunge?
- CalamityJames
Funnily enough, I just thought that myself! Now to find the how to guide!steve_earwig wrote:Strainer on the bottom of the fuel pick up (in the tank) full up with gunge?
It just occurred to me that it should be obvious - is your manual fuel primer bulb thing trying to turn itself inside out?
- CalamityJames
I had a look at it after my 1 hour drive to work and it was fine, and also firm, but I didn't get a chance to check it when it cut out (I probably should have done)steve_earwig wrote:It just occurred to me that it should be obvious - is your manual fuel primer bulb thing trying to turn itself inside out?
my 2.1 has done this twice in the 3 years ive had it.once i got the aa out amd they couldnt find a fault either g ot it towed home and 6 hrs later started first touch of the key was fine for about 4 months then did it again never found out what caused it.
- CalamityJames
Odd! Well, if I can solve it I'll let you know, it nearly did it to me yesterday morning too (the revs dropped to about 500rpm and giving it throttle didn't help at all)omega wrote:my 2.1 has done this twice in the 3 years ive had it.once i got the aa out amd they couldnt find a fault either g ot it towed home and 6 hrs later started first touch of the key was fine for about 4 months then did it again never found out what caused it.
I'll try and check the fuel strainer at lunch time at work!
- CalamityJames
Quick update: I think it's air getting into the fuel system. There's a larger leak than I thought on injector 1 and when i squeezed the priming bulb I could hear air coming out of what I can only imagine due to the location was the bottom of the fuel filter housing, possibly the thing on the left (looked like a white nylon screw sort of thing)
Sound plausible?
James.
Sound plausible?
James.
Plausible
Sounds like the valve for draining water out of the filter bowl
Hi
I am a newbie who is quite technically minded and experienced in household stuff - rewiring/plumbing/genreally fixing stuff but have never worked on cars.
My Peugeot diesel 2.1 estate (R reg, 220,000 miles) will now, without fail, stall and display the Engine auto-diagnostics warning light ( logo looks like this -K I told you i was new to this!).
It does this after about 4 minutes of driving. Requires re-starting each time. Getting worse (sometimes 3 times in a row). Usually fine once running temp is achieved but quite hazardous until then.
Please - if you know the solution - help. My local garage has changed "temp sensors".
Tempted to take to Peugeot dealer but dont want to throw a lot of money away on a 220,000 mileage car, and wonder if they could fix anyway if local garage cant
Many thanks on advance
Ted
Ted
- CalamityJames
Hi Ted,
The 'K-light' as it's known (it's actually a transistor) means the ECU has picked up a fault in there somewhere.
With my car, I've done away with the electronic injection pump so the K light is pretty much useless to me, however I'm assuming you haven't done this, so if you know someone with a Peugeot code reader the car should be able to tell you exactly what (it thinks) is wrong.
Alternatively you could invest in one on eBay yourself (this thread from a fellow 2.1 owner seems to have some useful insight)
Hope this helps!
James
PS: To anyone wondering if I solved my original problem, yes I did, the bleed off pipes WERE leaking and it's been fine ever since!
Hope this helps!
James
It's a long time since I drove my 2.1 but doesn't the K light come on just because the engine isn't running?
Don't go to Peugeot, they'll start off by saying your fuel pump has had it
- CalamityJames
Good point, I didn't think of that! In that case it could well be air getting into the fuel system!steve_earwig wrote:It's a long time since I drove my 2.1 but doesn't the K light come on just because the engine isn't running?
So far I've experienced air in fuel system problems due to, perished primer bulb, ageing leek off pipes and leaky injector seals. All these can make it a bitch to start and even cause me to coat the block with diesel from the bottom of the injectors but I've never had the engine cut out on me once it's running. Surely you'd need a large amount of air coming in to do that which in turn would mean a sizeable hole.
I might be talking crap but wouldn't a hole that big either make starting impossible or piss fuel all over the engine bay under revs???
Before I changed the injector seals i could see air bubble up around the injector when I blipped the throttle.
Thought, maybe the thicker veg oil wont pass through like the diesel did on mine but allows air in, you could try coating the likely suspects with a vaseline type gel and see if that helps. Put it on a cold engine and it should stop air getting in and therefore she'll stay primed and start easily, it will melt/burn off but it should point out the area you need to look at.
2003 2.2 HDI SE
2003 2.2 HDI SE
- CalamityJames
Mine was leaving little pools of vegetable oil under where it was parked, so I'd imagine it was a sizeable leak. It was also very tough to start.
The main leak off pipe between the pump and injector 1 wasn't the usual braided type and I think the internal diameter was too big. Fitting a set of new leak off pipes and a 1m pipe cut down for the pump to inj 1 from EuroCarParts (this and this respectively) seems to have cured all but starting it on 100% veg in the cold (to be expected really)
