Hello Dai
Well called the men in Yellow vans twice today
and got towed home!
Same Error codes all to do with
EGR Valve! P0403
Cleared them 3 or 4 times and kept coming back the same so 99% that is the problem.
First AA man blanked off the EGR worked for a while then gave up, second one just said where do you want to be towed too as the EGR had gone
IAT Sensor changed and that fault disappeared for good (Only £7.12 off the bay) wish the EGR was the same though, I know not
£147-£160 new or £60+ used with a 90 day warranty. Not that bad really could have been worse I suppose, but at least I have had new a Valve Solenoid, HP Fuel Pump, Cambelt and Inginition block fitted by the last owner, so the EGR was going to give up sooner or later, and from waht I have read nearly always about 100,000 + miles (mines on 107k) and its started at 103k
From the threads I have read on our site and others, it nearly always seems to be the EGR, AA guys said it is one of the common faults on modern cars that they deal with.
They are better now, but in 02 the first Petrol cars to use them 'with' all the sensors as well............ so problamatic, once fixed should go on for another 100k
Hope it can help others diagnose similar fauts in the future.
Seasons Greetings
