D8 Parts
D8 Parts
ive got my d8 sitting out front going nowere for 4 weeks untill my private plate is put on retention soo....
does any1 need any bits off it before it goes to heaven in 4 week.
Re: D8 Parts
Hi gaz
do you have to original door speakers,
couid do with a pair ,
Re: D8 Parts
i had custom install lozz so threw those standards years ago sorry mate ..
Re: D8 Parts
no probs
Re: D8 Parts
you got a rapier dash in there?
if so after the lower dash section on the passenger side in black plus access panels both sides
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: D8 Parts
wen u say lower section do you mean the back section to the glovebox ?
Re: D8 Parts
yes, the lower dash section behind the glovebox
Bring back my 406
Re: D8 Parts
yes i got full glovebox from a rapier all black... let me go check if its not broke cos i think i broke the glovebox door ...
i'll post u sum pictures is 10 mins
Re: D8 Parts
I've got a rapier glovebox, so as long as the soft closure will work, then I just need the rear section in black
Bring back my 406
Re: D8 Parts
just needs a good clean
plus i just spotted on pics its broke were the pin goes in to hold glovebox on
Re: D8 Parts
Is the radiator bottom hose the same as the 2.1TD?
If so, has yours ever been replaced? If it's the factory fitted one its connectors will be rusted to pieces, but if it's new(ish), I'd be interested...
Re: D8 Parts
I've got a pair of standard speakers that came from the front of my old Rapier.lozz wrote:Hi gaz
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: D8 Parts
its the original one mate rusted to peices . i replaced my radiator 12 months ago and managed to use the original one luckily..jonsowman wrote:Is the radiator bottom hose the same as the 2.1TD?
sorry cant help you
Re: D8 Parts
hi Gary, I'm looking for some screws and fixings. I'll point to this post that I made at Chief's thread. That's floor console rear bolt and dash-to-aircond blower housing screw.
Next are a bunch of screws that secures the wheel arch trim. It's number 71 in the picture below. ServiceBox says there are 31 of them. I need a bunch of them since quite a number have gone missing over the years. Lastly is the plastic pins that holds down the front grill with the badge. 4 plastic "rivets" as ServiceBox call them, mine's missing 2 in the middle.
I'm trying to restore all the parts best as possible. Maybe you can help? Cheers.
