Bloody things HUGE
How are you getting back?Bailes1992 wrote:Just been given a Transit T350 115 to drive to reading tommorow...![]()
Driving said Transit backDoggy wrote:How are you getting back?Bailes1992 wrote:Just been given a Transit T350 115 to drive to reading tommorow...![]()
Little green arrow on the dash. Thing is it wouldn't take into account if you were going up hills, so if you were at 30mph doing 1,800rpm in 4th it would tell you to change into 5th weather your going uphill or not.Welly wrote:I used to like driving the 5-cylinder Sprinters they used to do. I had the back end step out in 3rd gear quite a few times![]()
How does it tell you to change gear? not a buzzer/bleep surely?
Yeah I know the 115 is the power. Was quite impressed actually.trem1 wrote:Sam the 115 bit is the bhp so yep it'll feel about the same as your car.Transit's used to be 'the king of the road' but the not up to much these days
Welly the sprinters these days have t/c on them which is way to sensitive, not only cuts the power but brakes the other wheels to slow you down....nightmare now
You call that huge? They come bigger than that these days. My old Sprinter was the old long-long wheelbase (with the 3 rectangles at the back) & even with just the 100bhp engine it was fast as hell. Bloody loved that thing. Think the Sprinters started going downhill when they started making the ones with the gearstick on the dash. Everything just seemed cheap & nasty in them whereas mine was pretty solid all round.Bailes1992 wrote:
Tottally worn out after 300 miles in this today! But without a doubt the most fun I've had driving in a long time!
I'm also pretty sure its as fast as my HDi90 too![]()
What I will say is I'm a shortish lad, with long legs but a short body. There was only adjustment on the seat.
To reach the steering wheel I had to put my seat quite far forward, then put the seat up high so I didn't squish my legs to much, but also ment I couldn't stretch. Was quite uncomftorble.
The indicators are totally out of reach from the steering wheel and I REALLY DO NOT NEED A CAR OR VAN TO TELL ME WHEN I WANT TO CHANGE GEAR![]()
Also it seemed to loose traction way too easily, once this morning comming off a roundabout at about 1/3 throttle. Then again by Pensylvania near Bath commign round a sharp bend the inside wheel span, again with very little throttle. Then changing from 1st to 2nd at the severn bridge and it lost traction again. Although every time was when the van was completley empty, so think it's more to do with the fact it was RWD with no weight over it![]()
Either way, good fun
never understood why you cant switch it off properlyTooT wrote:You knock the system off but its not really off it will spin the wheels for a while but eventually bog down and stall. Still its better than a Transit. Actually id like a drive of the 200 bhp Tranny they do now.
