Bung it in there format it and put all your porn on it... job done.
Or do as i did and put all your other halfs tv episodes on it and lock her in the bedroom.
Wonderful, truly wonderful!
The easiest solution is a media centre PC, I put one in the bedroom last year and it's really handy.
Managed to pick up an ex-office Dell desktop machine with Windows 7 pro for £45, put a tv tuner in it and a 500 GB hard drive I had spare and Bob's your uncle.
I've got all my music on it and loads of DVD rips stored so don't need any discs, plus you can put any recored TV to disc fairly simply should you need to.
If you want blu-ray just slap a blu-ray drive in (may have to upgrade the graphics a little)
Dell desktops make good media centres as they're small, quiet and very energy efficient.
Media centre in 7 or Vista will wake the machine up for recording then send it back to sleep as well.
2003 2.2 HDI SE
I tend to avoid Dell from corporate experience. They are the Vauxhall/Ford of the computing world (ie. componentry on a budget, not what is best for engineering).
Build your own PC from a MiniITX board and a silent fan.
They're a bit more expensive but I've been looking at the new Commodore 64, even a barebones and building up my own system.
I used a Dell as it was small, quiet and cost £45, if the budget stretches I agree buy better components. But if my Dell breaks I'll just go and get another one for the same money.
My main PC I built from scratch using premium components as a gaming rig, so far I've thrown about a grand at it but don't tell the Mrs!!!!
2003 2.2 HDI SE
I purchased an item on ebay, but it was not a caddy, which i should have bought it was this: http://www.ebay.co.uk/itm/320383801768? ... 096wt_1156
it hasn't came with drivers, but worse than that the power adaptor i plugged into the mains and it blew up before even connecting it to anything, huge big sparks zappy electrical noise and a bad smell and just out of the box. The joys of cheap junk off ebay
But i think just as a temporary job i can use an old PSU i have lying around for the power and try and get the drivers somewhere, them minidisks dont even work in my laptop.
If you've had a bad smell theres a good chance it's blown the hard drive mate.... is there a light on that power adaptor since it blew?
the PSU didn't work they must need a signal from a motherboard to send power, but i have put the hard drive into the dvd recorder again, but just connected up the power and kept on the usb bit.
To scotty the light blew straight away, i hadn't the hard drive inserted into the power it blew on its own, that how good the quality was.
Good job you didn't it would probably have taken the hard drive with it... safe to say that power pack is now fooked... how it can do that by just plugging it in tho is another story.
this is it at the moment:
its got power going to it, the hard drive set to master but the computer doesn't detect anything, this thing is rubbish, the worst with this cheap stuff is to get a refund usually costs the return postage
Just leave some negative feedback, seeing as they did refund as you returned it. Some sellers I've used in the past still expected positive feedback even though the item is defective.
