Am i inviting Armageddon
Re: Am i inviting Armageddon
Well i tried removing the shunt fuse today , firstly i disconnected the
battery waited then removed shunt waited and replaced also battery lead ,
no difference . Then tried doing it followed by bsi reset , no joy . Finally
went the whole hog and pulled the fuse with battery connected , still nothing so
looks like connection to reader is called for and repair ? of bsi . :(
Sorry to hear that puggy,
iwas kinda hoping the bsi reset /shunt fuse thingie wouid work,
i hope the bsi repair bill dosent cost ya a fortune :(
I must admit I didn't hold out much hope, although I did hope you'd prove me wrong.
puggy wrote:looks like connection to reader
Que? You mean PP2k?
I've been squinting at the diagrams again, I can't actually see what goes where inside the switch no matter how big I (oh dear :roll: ) blow it up.
[thinking allowed] The BSI switches the earths to park the wipers via 2 relays. They should normally be parked and switched from the earth that's provided inside the BSI itself. If you can't hear the relays clicking then they're not going back to the rest position for some reason... The BSI is obviously turning the power off but. Nothing is directly wired between the switch and motor (apart from the washers), it's all just signalling between the switch and BSI.[/finking a lowd]
Why I'm looking inside the switch is I'm wondering if it could be the problem.
Dammit, I can't figure out the wiring for either switch when they're parked. Try another switch - should we have a vote?
Yep steve thinking it needs to go on pp2k like doggy suggested " to give it a scare " :shock:
As regards your other theory , the switch , i will go along with that after the window switch
episode , think that is well worth trying and a quick easy to test option .
90 quids from Pug :( I'm guessing it needs automatic and trip computer, as well as rear wash/wipe. Looks like 6239 A7
N E good? http://www.ebay.co.uk/itm/2001-Peugeot- ... 19cbe1ce1c
Cheers steve , got it for £8 so hopefully we shall soon see :P
8 quids! :shock: That's fantastic :cheesy:
Yes it is !! although if it doesn't work it will cost me considerably
more to travel over there to you to insert it in your rectum :twisted:
Seriously though thanks for that and he accepted my first offer , well pleased :)
Tried the switch steve , no different so guess its down to the bsi ?? :(
Buggeration :( It sure looks that way :frown:
just googled it , found someone else with exact same prob , he changed
ecu , bsi , wiper motor and stalk didn't work , finally traced it to the yellow
plug that goes into bsi , not all the spade contacts were touching , shall give
that a try :roll:
Post a link!! It'll be one for the Knowledgebase :wink: Ooh, and if you do have the same problem, take some pictures of it (pretty please with a cheery on top and spam :mrgreen: )
